Results 1 to 3 of 3
Thread: 2002 Z3 wiring Question - trunk "pitch sensor" - Help !
    Mar 2004
    Seattle, USA
    2002 Z3 ,2001 BMW 330ci
    Pitch sensor, bottom of left side of trunk found in 3" of water - sensor and loom plug ruined ! Alarm goes on at off at will while driving. Not fun. (Though one Escalade pulled over, driver was distressed!)
    My USA Z3 2.5i wiring has a red/yellow (hot always) wire that's not shown in Bentley wiring diagram - ( this is part of the (DWA) Anti-theft system - page ELE-170 of Bentley manual.)
    Can someone look at their wiring and see the same wire and in what "position" does it fit in the X1222 wiring loom plug ? My wire was not attached to the plug at all, but it had been.
    I have a new BMW plug with new connector inserts. I presumed this yellow/red wire was supposed to line up with the #3 pin on my new pitch sensor on the wiring diagram.
    However, after careful install, when I re-attached the negative battery terminal to test, the fuel gauge and engine temp gauge went inoperable, I found a 5 amp fuse blown, part of the DWA anti-theft fuses.
    Not excited to ruin my expensive new sensor - if it's not already fried.
    If nothing else maybe you can make sense from the wiring diagrams you may have or the Bentley diagram referenced above.
    Thanks in advance, -- any help much appreciated.
    David J.
    Seattle
    Jul 2004
    Houston, TX
    36 Cylinders
    Use this instead https://drive.google.com/open?id=11B...x5xKeT61uGeH0P
    Save the pdf, open it locally on your own computer, it has clickable links to pages.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2004
    Seattle, USA
    M.D. WIP , Thank you very much -- that's cleared things up immensely.
    David Johnston
    Seattle, Wa
    2002 Z3 2.5i
    2001 330Cic
  1. 2004 engine into 2002 330ci - wiring question
    By johnnyz in forum 1999 - 2006 (E46)
    Last Post: 11-15-2012, 07:06 PM
  2. speed sensor & speed sensor wires question?
    By bimmer213 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-13-2007, 02:36 PM
  3. Brake sensor wire question
    By Uber3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-13-2007, 08:00 AM
  4. 2002 z3 (or z4?) Business CD question
    By morganbressler in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-27-2006, 12:31 AM
  5. e39 wiring in trunk question
    By Noman in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-24-2003, 04:28 PM
