Results 1 to 17 of 17
Thread: Help on wiring electric fan
    Jul 2010
    baldwin, ny
    2003 540MSPORT 6 #861
    ok now I have to correct the mistakes of the past mistakes I paid for the so called professional work- no i will not go back and ask for them to correct - I have to do it myself- I have have had constant fuse blow outs on the ZIONSVILLE electric fan - the fuse either blows or melts- I need to re wire the the thing myself to does anyone know where it should be properly wired to in the ECU box? Yes I will take pic to show the present poor work- right now it is wired so that the fan is on constantly -
    2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
    Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
    36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
    EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4
    cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Mel, if the fuse if blowing/melting it could be the wrong amperage and the wire gauge could be too small.
    What did they put in?
    My fan gets its power from the battery post on top of the valve cover.
    Jul 2010
    baldwin, ny
    the wire looks thick - the fuse used was 15 but kept blowing and then melted- I stuck in a 30 which held but again melted - my son yelled at me- so now I removed the fuse he says it needs to be re wired- they wired it to the top of the box- let me take a shot to show you- - now I'm getting a whole bunch of crazy readings like brakes light and side lights are off but not true hope something isn't totally fried- at same time having a bad leak --
    Jul 2010
    baldwin, ny
    here is the mess-
    Jul 2010
    baldwin, ny
    and the many melted fuses
    so Jim I should wire the fan to the Battery post on the valve cover?
    Jim can you shoot me here a pic of yours?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    I'd love to agree w/ your son, and normally I'm on the don't put a bigger fuse in! camp completley, but its supposed to be a 30A according to ZV website.
    http://www.zionsvilleautosport.com/a...tic-single.pdf
    That blown 30A looks EFFED UP. Something seems dramatically out of order. The look of that splice w/ the electrical tape over it ain't good either.
    Basically the idea behind Jim's wiring is to keep the power supply to the relay as big and direct as possible. His setup pix won't help you 100% because he's built his own PWM motor controller in a housing so its an entirely different thing but the basic idea to use the jump-start cable would still work, just try to keep the wires from that to the fuse & relay & fan as short and clean as possible while still being tidy.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Jul 2010
    baldwin, ny
    holy moly 30A !!! ok well now somehow all this has to be cleaned up and brought back to code- what a mess- I guess I have to call Zionsville up and get a replacement fuse relay and more to do it right -
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Holy crap! As bad as that fuse melted, there's gotta be more melted wires somewhere else too.
    Jul 2010
    baldwin, ny
    Quote Originally Posted by BimmrMeUpSnotty View Post
    looked at the whole loom only that wire fuse was the culprit
    Mar 2010
    So, the motor is drawing too much current. Ways that could be happening:
    - resistance in the crappyass connections splices etc
    - too small wires, too long wires
    - fan physically dragging or binding so it has to work harder
    - short circuits someplace
    Pull it apart. See whats what.
    2003 M3CicM6 TiAg
    Former:
    Jul 2010
    baldwin, ny
    I'm hoping my son will help me tackle this project - Mr B tech currently -
    JimLev's Avatar
    Sundance Mesa, NM
    That fuse socket has to be toast too.
    I ran a heavy gauge wire from the 12 volt jump connection down to a separate 4 fuse terminal block that I mounted low and in front of the oil filter housing. Each fuse feeds different circuits I added......Flex-a-Lite fan, nitrous 1st stage, 2nd stage, AE's, etc.
    You could get the parts you need from ZV or some local parts store. You probably need some 10 gauge wire, terminals, a 30 amp fuse holder, fuse(s), and maybe a 40 amp relay.
    You must have some electronics parts store on LI where you could get these parts from.
    Jul 2010
    baldwin, ny
    oooo awesome!!!! now that you told me this YES and when my son gets back he can help me with this- so we'll make our own - yes plenty of shops here to buy and make our own- so use what you listed-- ironic you mentioned the NOS- he just made his own direct injection individual port for the LS NOS squirters gonna common it with a plate- you suggest to have the fan on all the time or a switch?
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Likely bad fuse holder as Jim said. Lots of cheapie fuse holders from China that fail to grip tightly on the fuse prongs. This creates a loose connection on the fuse which heats up and causes the fuse to overheat. I had the same exact issue on my car. I changed to a better fuse holder that I ensured had a tight connection to the fuse prongs and have had no issues since. Change out your fuse holder to a better tighter one and you should be good. Or redo the whole set up as said above. Just ensure the fuse holder fits tight on the fuse prongs.
    This issue wont show up on smaller amperage things, but the fan really sucks some power. Loose fuse holders show their ugly heads for these type applications.
    Jul 2010
    baldwin, ny
    which type of fuse connection did you end up using?I'm shopping right now for a replacement and instead of replacing with the same type maybe I should look for something different?
    Quote Originally Posted by philly98540 View Post
    Mar 2012
    Lansdale, Pa
    I ended up going to my local auto parts place and bought the couple that they had. I picked the one that really fit tight on the fuse prongs. I forget what brand, maybe bussman or something. Make sure its rated for the amps you need, and check for a tight fit on the fuse. Sucks that a $4 part could cause a fire and destroy your car.
    Jul 2010
    baldwin, ny
    tks for the advise- yes i still have to research in person - I found this at home depot LOL but haveattwood-boat-hardware-14347-6-64_1000.jpg to test the fitting
    Extra heavy-duty 30-Amp/12-Gauge in-line fuse holder. For ATO/ATC fuses. Water-resistant.
  1. Help wire electric fan
    By BimmerGuy328 in forum 1991 - 1999 (E36)
    Last Post: 05-15-2015, 09:46 AM
  2. Help wiring Electric Fan
    By redbull713 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-02-2012, 03:37 PM
  3. trying to wire electric fan, need help.
    By SS Ball3r in forum 1991 - 1999 (E36)
    Last Post: 03-27-2008, 05:04 PM
  4. need help on wiring air/fuel gauge
    By momo1979 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-19-2007, 12:49 PM
  5. Emergency Help Wiring Electrical Fan
    By bimmeracer3 in forum Forced Induction
    Last Post: 09-17-2007, 04:13 PM
