Results 1 to 9 of 9
Thread: Fuel regulator - solved
    Apr 2012
    California
    e30M3,F355,BentletGTC,RR
    Hey guys, does anyone know where the fuel regulator I should located in a 1995 840ci? Recently it’s been taking longer to start the engine. I changed fuel filters but the problem remains.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    That could be the check valve integrated with the pump or the regulator. If the pressure bleeds off, the car will take forever to start. Luckily, it is an easy solution either way. You could buy a fuel check valve and stick it inline before the filters. The regulator is on the end of your fuel rail. Easy change out. Probably quicker to change the regulator than to pressure test your system to verify which component failed. I'd change the regulator first.
    Brett
    Apr 2012
    California
    Thanks Brett! So it’s located down line from the filter underneath the car right?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    for such cases the workshop manual helps https://www.bmwtechinfo.com/repair/main/721en/index.htm
    13 - fuel system M60
    see page 13-51/32, under the manifold cover
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The fuel pressure regulator is on the rear of the inlet manifold - details here:
    http://www.meeknet.co.uk/E32/PCV/Index.htm
    My BMW Repair YouTube Channel
    Apr 2012
    California
    Sorry guys it’s been awhile lol. I replace the whole setup; fuel filters, fuel regulator and fuel pump because they are old. Turned out it was the fuel pump going bad.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    Glad you got it sorted.
    Brett
    Fayetteville, GA, United
    '95 840Ci/6, F36, E89
    Yeah, that fuel pump was a joy to change :-)
    Apr 2012
    California
    Small correction. The fuel regulator was bad not the fuel pump.
  1. Cheap Fuel Regulator
    By Racer X in forum 1983 - 1991 (E30)
    Last Post: 03-03-2011, 01:27 AM
  2. Bmp Vdo Fuel Regulator
    By RMS343RWHP in forum BMW Parts For Sale
    Last Post: 04-02-2004, 10:33 AM
  3. NOS setup and adjustable fuel regulator 50-70 shot
    By nick325i in forum BMW Parts For Sale
    Last Post: 11-19-2003, 12:49 AM
  4. adjustable fuel regulator
    By nick325i in forum 1991 - 1999 (E36)
    Last Post: 01-22-2003, 09:16 PM
  5. Help: Picture of Fuel Regulator.
    By patlam in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-14-2002, 08:26 PM
