Results 1 to 6 of 6
Thread: Hood Lock Woes. Hood won't open on passenger side.
    Feb 2017
    Southeastern Connecticut
    1995 740IL
    Hello everyone. I know this topic has been beaten to death, but most solutions are the same and they will not work in this case. I have a slightly different problem and I could not find a solution to it. Problem: The passenger side hood lock (BMW Part#52138164764) arm has completely disengaged the lock assembly. The arm I'm talking about has a receiving ball on one end.
    Probable Solutions: 1) Cut the hood to gain access. 2) Drill the lock in several spots and pray it disengages.
    Any ideas would be happily welcomed.
    My Ride: 95 740il
    Jan 2016
    Ca
    2001 525it
    Cut the hood grill out
    Feb 2017
    1995 740IL
    Both kidneys have been removed.
    Feb 2017
    1995 740IL
    Feb 2017
    1995 740IL
    latch 7.jpgHood latch on the car currently, viewed from the front of the car with grille removed, on the passenger side. The piece circled above is located on the other side of the hood latch facing the engine bay but it has all come apart including the release lever, spring, and cable as shown above. So now all there is left is a hole where the release lever used to be.
    Feb 2017
    1995 740IL
    I managed to cut the wind duct open. I drilled the side of the lock housing, its plastic. I used a flat screwdriver to pry the cover off the lock.Once this was done the hood popped up, and the remaining pieces of the locking mechanism fell on the ground. Sure beats having to pay a BMW dealer over $1000 to get my hood open. Took roughly 20 minutes to complete. Again, Thanks, Edwin!
  1. Trunk Won't Open on 98 E36
    By oldschidc in forum 1991 - 1999 (E36)
    Last Post: 09-21-2016, 09:29 PM
  2. Hood latch won't release on one side
    By janjan64 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-16-2015, 10:30 PM
  3. Rear Drivers Door Won't Open on E39
    By izzrock68 in forum 1996 - 2003 (E39)
    Last Post: 02-01-2013, 11:28 AM
  4. Remote locks doors but won't open them
    By Edgemar in forum 1991 - 1999 (E36)
    Last Post: 12-12-2012, 09:49 AM
  5. Replies: 0
    Last Post: 08-08-2006, 05:32 AM
