Results 1 to 7 of 7
Thread: Window regulator track pulled off
    Jun 2006
    Seattle, Washington, USA
    1996 328i
    The window regulator track on my 1996 328i pulled off of the right rear window glass. Please let me know how to properly reattach it.
    Oct 2003
    Seattle
    99 M3
    Most likely need a couple of these replacement clips, p/n 51-32-1-938-884.
    https://www.ecstuning.com/b-genuine-...kaAtEnEALw_wcB
    Jun 2006
    1996 328i
    The aluminum track pulled away from the glass. The plastic slider and clip are in ok condition.
    Apr 2014
    Castlegar,BC,Canada
    94e36M3RIP, 95 318 S50
    I would try urethane window sealant
    Jun 2006
    1996 328i
    FYI the dealer recommended using a two-part epoxy.
    Nov 2016
    texas
    1998 328is
    had this issue too first things first if the metal clip is missing or if the plastic slider piece is broken that could be a fault, if they are fine then check if the window is in the guides in the front and back because if not the window will keep falling off the regulator ball joint,
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    http://www.realoem.com/bmw/enUS/show...diagId=51_2121
    Item 2 is the object of your desire. Sorry, I lied, this is the front door, the rear door may be different.
    Unless the window regulator is bent, the only thing that can happen is that Item 2 breaks, or the metal clip falls off, which only happens if Item 2 breaks. YOU MUST LOOK UP THE RELATIVE PART FOR YOUR CAR, THIS DIAGRAM IS FOR MY 'VERT.
  1. Window Still Popping Out, Off Track - New Window Regulator and Sliders
    By persiandude in forum 1992 - 1999 M3 (E36)
    Last Post: 08-01-2017, 08:52 PM
  2. Window regulator/track question
    By pashramm in forum 1991 - 1999 (E36)
    Last Post: 11-12-2016, 07:43 PM
  3. DS window regulator channel popped off
    By jmenacker in forum 1988 - 1996 (E34)
    Last Post: 09-08-2014, 12:27 PM
  4. First repair on the new car: window regulator guide track
    By subrock in forum 1988 - 1994 (E32)
    Last Post: 01-30-2010, 08:39 PM
  5. Street and Track Tire Pull-Offs!
    By goquattro in forum Texas
    Last Post: 02-20-2009, 06:07 PM
