RM European Auto Parts
Results 1 to 3 of 3
Thread: 08 535i transmission malfunction
    Feb 2018
    Oregon coast
    08 BMW 535i sport packag
    So my car (08 535i sport automatic) has had issues since I bought it but I love it anyways. The issue I'm currently having is one that was one that presented itself right after I bought it. Floor it or give it more gas to pass someone or accelerate quickly and the transmission goes into fault mode after trying to up shift or when it downshifts after the acceleration and feel like it does shift but then glitches out. I had a bad voltage regulator relay that was frying my battery and alternators and that was what I thought the problem was. I fixed that. Few weeks later I'm getting on it to put a plastic mustang in it's place lol and the transmission faults. When it happens I pull over and and shut the car off restart it and the issue is gone. Not anymore. Now it will continue to do it any speed over thirty. Tried babysitting the pedal or flooring it. Doesn't matter. Will still go into fault mode the moment the transmission tries to down shift up or down. Tried in steptronic with paddle shifter and same issue. Right around third and fourth gear. Any thoughts on what I need to replace? I am on va disability can't afford stealership fees and am mechanically savvy anyways so if it's a part I can replace without a shop or hydraulic press or any computers I can handle it.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Just as a note, please do not use the term "stealership" here, as we have several Dealership Tech's that you are offending.
    Second I would like to thank-you for your service from one brother to another.
    Third, you will get nowhere on this car without a proper diagnostic tool. There are several on the market from a Foxwell hand-held unit to the BMW ISTA suite, and of course the prices will vary. What I would do if you have over 75k miles is start with replacing the trans filter and fluid. This would be purely preventative maintenance anyway, and you will still need to get the fault codes out of the trans and post them up so we can assist.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Versions of the 6 speed auto in earlier year 5 series occasionally have transmission valve body solenoid problems. You can replace solenoids. There are kits and DIY if you search. This could be the issue in your 535. Changing the fluid and pan with integrated filter is not a bad idea. BMWs idea of lifetime might not be your idea of lifetime. You can buy kits for this also. And there is a mechatronic sleeve that can leak. The best 5 series tech info that I have found is on 5 series dot net though you can also find some that is applicable from the N54 guys on n54 tech dot com. A good scan tool definitely helps—the generics don’t do enough. Something like the $150 fox well nt510 gives you a free bmw specific module when you register it. There is also bmw Carly. And there are much better much more expensive factory levelTools we would all like to have but aren’t in the average DIYers budget, though smart computer geeks have put systems together for a few hundred dollars — check the diagnostic forum here for the best info on that.
  1. 08 E60 550I 140K Miles Transmission Malfunction
    By eondi66 in forum 2004-2010 (E60,E61)
    Last Post: 04-24-2017, 03:26 PM
  2. E60 M5 Transmission Malfunction
    By 2006M5 in forum 1996 - 2003 (E39)
    Last Post: 05-21-2006, 05:25 PM
  3. 1986 535i transmission
    By missionaryman in forum BMW Parts For Sale
    Last Post: 03-11-2006, 09:33 PM
  4. 535i transmission problem
    By stylin5speed528 in forum 1988 - 1996 (E34)
    Last Post: 07-31-2005, 02:45 PM
  5. 535i Transmission
    By Goathumper in forum 1988 - 1996 (E34)
    Last Post: 02-22-2005, 10:18 PM
