Results 1 to 8 of 8
Thread: Engine shut down rattle?
    Apr 2017
    Sc
    1987 325e, 1989 325i
    Does every m20 kind of rattle like a rock in a shoe box for maybe 1 second when you turn the key off? What’s the source of the noise?
    1987 325e, coupe, 5speed
    1989 325i, sedan, 5speed
    Jan 2016
    Ca
    2001 525it
    The m20 can make a familer knocking noise I just cant remember when I would hear it
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    Ha ha ha, not all.
    NW suburban Chicago
    hiss by my window
    Not sure if your car has a dual mass flywheel but that rattle you describe is the classic symptom of one that has failed.
    Valencia, CA
    Imola E36 M3 E30 Touring
    Could be your transmission making that noise. The flywheels on M20 cars are not that great at dampening rattle, and the Getrag transmissions are inherently quite noisy.
    Does it happen if you turn off the car with the clutch pedal held down?
    Apr 2017
    Sc
    I’ll try it, thanks. It doesn’t sound bad, just something making noise when things stop turning, I think it only happens when everything is heat soaked from a long drive.
    Nov 2017
    Oklahoma
    1989 BMW 325IS
    i have the same issue but it doesn't make that sound if the clutch is pushed in
    Valencia, CA
    Quote Originally Posted by Backfirex70 View Post
    Getrag rattle. The transmissions in these cars are known to rattle when in neutral.
  1. over rev going to 5th ended in 3rd engine shut down ...
    By mindstorm00 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-01-2010, 02:08 AM
  2. Need to disconnect/reconnect battery after every engine shut down
    By krazychikka in forum 1991 - 1999 (E36)
    Last Post: 01-27-2009, 12:57 AM
  3. help: Engine shuts down after cold start.
    By JuM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-23-2008, 06:33 PM
  4. beeps 10-15 minutes after engine shut down
    By tdoza in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-07-2008, 11:38 AM
  5. Replies: 13
    Last Post: 01-25-2008, 01:36 PM
