Results 1 to 2 of 2
Thread: Cooling for SC E36
    Dec 2012
    Northern California
    1999 Dinan S3 M3
    Cooling for SC E36
    I have a Dinan Supercharged E36 M3. Added a euro oil cooler and Z3 S54 radiator. RMS After Cooler is a wish list item but at 1800 its a big ticket item. Things still get warm under the hood so I run the heat in the cabin while running it hard. The needle doesn't move on the thermostat (stays in the middle) and I don't have gauges yet but its pretty hot under there. I am buying a stock hood and want to put in the gtr style hood vents for cooling. I have researched this and read it helps alot with cooling. For the guys with vented hood and high power setups is it worth venting the hood and if so are there other items to be done while doing so.
    1999 Dinan 3 Supercharged M3 Alpine White (Open to Selling)
    2017 Tesla Model X
    2018 Land Rovery Discovery Diesel Off-Road
    1995 M3 5 Speed Cosmos Black (SOLD)
    2008 550i M-Sport (SOLD)
    2011 335i 6 Speed Alpine White (SOLD)
    2004 ZHP 6 Speed Grey (SOLD)
    Mercedes GL550 (SOLD)
    Formula 252SS with 502 Mag/B1 (SOLD)
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    You shouldn’t have any problems on the street with your low boost system. If you track it, you should be prepared for power loss from heat soak since it is not intercooled and from the added drag on the motor under boost since you will be in boost much more on the track. Proper ducting and sealing helps but if you track it you will want an oil cooler. Once you add the intercooler and raise the boost, the ducting and sealing will become more important as will the oil cooler and heavy duty engine fans. Water/meth injection will also help with detonation suppression since you are on 91 octane in CA. You will benefit some from water/meth even now with low boost.
  1. vanos switchover for SC'd e36 m3?
    By slimjim in forum Forced Induction
    Last Post: 01-17-2005, 04:05 PM
  2. Clutches for SC E36 M3
    By Bruce M. in forum Forced Induction
    Last Post: 12-15-2004, 08:38 PM
  3. Best Clutch for a SC E36 M3
    By Mechanic69 in forum Forced Induction
    Last Post: 09-19-2004, 05:23 PM
  4. Advice on a SC for sale - E36 325
    By mck325is in forum Forced Induction
    Last Post: 05-11-2004, 12:32 PM
  5. Stay cool with a Victory Competition Oil Cooler Kit for your E36 325/328/M3
    By BGM3 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 04-21-2004, 07:02 PM
