Results 1 to 25 of 45
Thread: 22RPD Tunes
    Virginia
    97' m52 turbo
    22RPD Tunes
    I saw a thread awhile back about RK Tunes. https://www.bimmerforums.com/forum/s...hlight=misfire
    I wanted to start a similar one for 22rpd
    Is anyone here running a 22rpd Tune and what are you experiences with it? From start to finish?
    Boston, MA
    E36 M3 Turbo
    Zack is awesome. Not only does my car run great but he's helped with just about every step of the process. Answers messages usually within minutes even for questions I've asked already lol.
    My setup was one he didn't have "off the shelf" being pump 93 s52 with huge ID1300 injectors. He had an e85 tune on hand but I wasn't ready to make the swap. After a couple revisions I was boosting. And since then he's made little adjustments as needed even staying up some nights past midnight for me to get logs and continue remote tuning. I'd recommend 22rpd all day long. Getting a dyno tune from him at some point this year to make things even better
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
    Jan 2018
    Arizona
    93 325is
    Who's 22rpd and how much are his tunes?
    Sent from my SM-G935V using Tapatalk
    Apr 2014
    Greece
    M3 e36
    @MilKt,
    Now you are advertising for a not vendor,see comment number 30 below .
    RK has the most experience period, and also tuned a lot of high powered cars,
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by M3turboE36 View Post
    @MilKt,
    Based on your very limited and "focused" posts here in the last few years,
    you have an issue/resentment with this vendor.
    I share your passion for focused anger.
    We all need a goat.
    Care to share some valid reasons for your hate?
    Manchester, N.H.
    96 332IS 6466 turbo
    @MilKt,
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Manchester, N.H.
    96 332IS 6466 turbo
    My very limited personal indirect experience with RK has been pleasant. The White car I built for E36Mylo who purchased an RK tune has been flawless. I will note that.
    1996 332IS
    Built 3.2
    Apr 2014
    Greece
    M3 e36
    Quote Originally Posted by milKt View Post
    We all need a goat.
    No hate here ,just stating the facts.
    North Carolina
    '86 M635/'10 Clubman
    The fact is that if you keep stirring you're going to spend some time on the sidelines. Play nice. There won't be further warnings...
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    BRB grabbing popcorn.
    Tooner threads are always fun.
    Okay everyone, commence!
    Mar 2012
    Renton, Wa
    98 m3
    Im personally a fan of 22rpd... :eatpop
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Vancouver, B.C., Canada
    '97 M3
    I’ve been around on BF FI for a long time now. I’ve had a couple TT tunes and an evolving RK tune. All the ‘tunes’ have had issues but which were directly related to hardware problems and the lower octane fuel that we have up here. Doing a remote tune with a hardware set up that isn’t 100% can be very frustrating for the owner and the tuner. And when an engine pops during the process the tuners get a bad name when the car it self was not properly sorted. I popped a hand full of head gaskets and cracked a head with my TT tunes and melted a piston and cracked a head with an RK tune. None of which were the tuners fault. Mostly a result of HP greed and some bad luck. You have to pay to play when you want a car to have three times the original HP.
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by chikinhed View Post
    You have been around long enough to where you shod be a tuner yourself at this point.
    1996 332IS
    Built 3.2
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have had a TT 60 lb obd2 tune for 8 years and never had an issue. 2 different engines (did a forged rod and piston build in 2014 for more power) and 3 manifolds and 4 turbos and stock head with stock cams and ported big valve head with Schricks). Runs great with anything. Will likely retune this year with 80 lb injectors for more power potential.
    milKt's Avatar
    Quote Originally Posted by 328iFun View Post
    This is the question.
    Boston, MA
    E36 M3 Turbo
    My stock motor didn't last. Naturally I blamed the tooner, why else can't my 200k mile engine handle triple the power?? All the cxracing people have been doing it for years
    Feb 2008
    DETROIT
    E36 GOODNESSSS
    We have 22rpd 1700cc injector tuneon my brothers car and we are working on 2000cc injector tune with Zack as we speak for my personal car so I can run nitros and boost . E85 tune and -30 degree tune and drives are awesome . I can complain , plus Zack has been giving me revisions and asnwering phone calls for my and my customer cars @2 am . Customer service is A1 and matter to me very much !
    Jun 2005
    New England
    Is the customer service at 2am from a call center in India?
    Feb 2008
    DETROIT
    E36 GOODNESSSS
    No sir , weekends late nights
    i got these parts for sale
    front corner light for a 4 door E36 $20plus shipping
    headlight eyebrows $20 plud shpping
    M3 OEM radiator $100 plus shipping
    M52 cams with trays high miles $150 shipped
    M3 front calipers $150 plus shipping
    18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
    obd2 valve covers $50 plus shipping
    intake manifolds $50 plus shipping
    estoril blue doors of a 96 M3 2door $200 plus shipping each
    rear glass $50 plus shipping
    rear trunk lid $150 plus shipping
    new 1/4 is 800 ft away ))
    Boston, MA
    E36 M3 Turbo
    There was one night I was driving and logging, pulled over to a closed Starbucks. Sent him the file, had a revision in my PM within 20min. Remote tuned the sumbitch in the parking lot while hanging with some buddies. LOL
    '97 M3
    Back in the day, I had to ship my ECU from western Canada to TT in Florida to get a revision loaded. I would assume TT doesn’t require that any more as it was very slow and costly.
    Jun 2005
    New England
    I have never had a revision so I don’t know. I assumed I would send him my ECU when I do the 80 lb tune. Or send him another ECU.
    Virginia
    97' m52 turbo
    Yeah, Zack has been good to me so far so It's great that others have the same experiences. Remote tuning makes it so easy now. Effortless really. Being in IT if I didn't have RDP I would get literally nothing done in a days worth of work but then again I would then have more people...
    The only thing that all tuners lack I think is explanation or whats actually involved in the tune. And I feel that a lot of them don't want to talk about it or explain because either;
    a. most people wont understand it
    b. they don't want their methods/maps known by competitors.
    I have always been the type of person who has to know how something works or the way its setup to the T. so when something does go wrong I can have a better idea where to start.
    Example being: When I got my tune I thought that I would still have misfire codes for when I needed them. There probably the most convenient part of the OBDII system if you ask me. But with a turbo tune you can't... which sucks and a few other odds and ends. But I guess you don't know if you don't ask.
    And onto 'revisions'... I've heard well the tune has worked on X amount of cars perfectly fine so it must be your hardware (and there probably right). But are all cars really the same? I mean all cars have the same exact hardware and built to the same exact spec? And 1 single tune can work on them all exactly the same?
    Jun 2005
    New England
    If a tune is done right it is very flexible. Never had a revision. My TT 60 lb blow through tune has run great for 8 years with 4 different turbos, 3 different manifolds, 0.140 MLS motor with stock cams, built low compression motor with big valve head and Schricks, with and without water/meth, with the wastegate disabled for no boost, at 10 psi boost, at 20 psi boost, in 95F weather, in 0F weather, whatever.
    Virginia
    97' m52 turbo
    TT is technique Tuning, right?
  1. 22RPD Tuning
    By Vettett15 in forum Engine Tuning
    Last Post: 02-21-2018, 09:00 PM
  2. Replies: 73
    Last Post: 06-06-2016, 02:16 PM
  3. Still tuning the SC at Active...
    By MSaloon in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2001, 10:21 AM
  4. Any1 know the ES tuning website or contact info ?
    By Rahul325 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-18-2001, 02:01 PM
  5. ES Tuning exhaust?
    By axion911 in forum 1991 - 1999 (E36)
    Last Post: 03-13-2001, 07:20 PM
