Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
Thread: yet another E36 M3 Dinan supercharger install
  1. #51
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by carguyspeaks View Post
    So I’ll have opportunities while the SC install happens.
    Vanos, various gaskets that are leaking. Radiator, water pump, a/c compressor
    Any other thoughts?
    Fan ? If so why?
    Sent from my iPhone using Tapatalk Pro
    Stewart water pump is highly recommended. Behr Z3M radiator or better. If in the budget get the Zionsville fan shroud with metal expansion tank. You’ll need to ask for offset fan mounting for s/c setups. Refresh your hoses (OEM) and thermostat / housing.
    Run a push/pull fan setup. OEM front aux with a Spal puller. Delete the mechanical fan either way.
    Get all the belts, pulleys and tensioners fresh now. They are very difficult to do once the charger goes in.
  2. #52
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Is the electric puller fan to reduce parasitic drag? Or does it cool better too?
    I have an overhauled cooling system already, but the fan isn’t electric
  3. #53
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    My tensioner & pulleys have tight clearances. Trying smaller pulley on the tensioner. Dayco makes a nice 74mm (2mm smaller)
  4. #54
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Metal instead of plastic. I like it.
  5. #55
    Jan 2014
    portland, OR USA
    96' 332i RMS stg2 SC'd
    I have the RMS pack list, install instructions for the aftercooler and supercharger as well as a few pics of belt routing etc. Shoot me your email if you'd like them sent to you.
    -nic
  6. #56
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Nic
    Thanks, I am still seeking RMS instructions, they have been “unhelpful”.
    Water wetter, good idea
    I have a used Nic G tuned ECM
    I doubled down on cooling enhancements.
    -new radiator
    - new water pump
    - new head gasket
    - electric fan
    I see PNW in your title. I’m flying to my dads in Renton Thursday. Then driving down to Bend for the weekend. I hope it’s not raining
    Much appreciated with the RMS instructions.
  7. #57
    Jan 2014
    portland, OR USA
    Small world, I'm in the Portland area. just sent you the instructions, have a good trip!
  8. #58
    Aug 2002
    Denver, CO
    '98 M3
    I wouldn't do the head gasket just because. Put the kit on and run it, I've run tens of thousands of supercharged miles on factory head gasket. Worst case is you need to replace it in the future some time
    '03 911 Turbo 6MT fun car
    '18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
    '15 Cayenne Diesel Wife's DD
    '17 KTM 690 "Adv" 2 wheeled Adventurer
  9. #59
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Noted
  10. #60
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Wonder how long my clutch will live ?
  11. #61
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I think I’m going to pack up all these bits & save them for winter, maybe a few years from now. Just can’t stand being without the car for the installation. I need two M3s
  12. #62
    Jan 2014
    portland, OR USA
    Before you pack them up can you do me a favor and tell me the length and fitting size of the oil feed line? I think it would be -4AN? RMS wants $195 for a new oil feed assy. I only need a new line...
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    K. I’m in Bend. Will be back home Monday
  14. #64
    Jan 2014
    portland, OR USA
    gracias! should be a nice weekend down there!
  15. #65
    Mar 2015
    Wichita, KS
    1995 M3, 2011 335i
    Quote Originally Posted by pacificNW View Post
    I ordered the turbo feed line with -4 an fittings from Rally Road. I haven't installed my kit yet, but the line appears to be about 2' long. I'm planning on using their vanos banjo bolt for oil supply and then using the 1/8" to -4 an adapter for the feed on the SC. All in, it was about $65.
    Side note, I just PM'd you about getting the install instructions for the RMS kit.
  16. #66
    Jan 2014
    portland, OR USA
    Got my kit all done finally. ignore the yellow headlights
  17. #67
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Looks good. I like the catch can placement and routing.
  18. #68
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Relocation brackets?
    I see I need to relocate cruise control and Power Steering stuff. Anyone have pics of these brackets ?
  19. #69
    Jan 2006
    Oakhurst, CA
    There are no relocation brackets for cruise control and RMS available. You either have to delete cruise (it really isn't that big of a loss) or relocate it yourself. The cable is just bicycle brake/shifter cable so you can extend it if needed.
    Power steering reservoir just needs to be moved closer to the block. A piece of steel flat stock with holes set to your desired location is all it needs.
  20. #70
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Deleting cruise control doesn’t generate any annoying codes?
  21. #71
    Aug 2002
    Denver, CO
    '98 M3
    Car isn't smart enough to know the cruise control is gone. Not a CANBUS system...
  22. #72
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Cool. On less thing under that cramped hood
  23. #73
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Well. Now that I’m ready to install I’ve decided to get divorced, sell my home and buy a Porsche 911. So I’ll be selling this setup when I get it unpacked. Perhaps the M3 too
  24. #74
    Conifer, CO
    M5, M Coupe, E70D, LRD2
    Bump.
    I bought this kit from OP last fall and finally getting around to installing it. Just a few questions.
    I'm going with a catch can instead of the check valve. So I block off the big hose supposed to go to the check valve?
    Does this use a bypass valve? If so, where is it plumbed?
    Do I need to tap into the brake booster vacuum line? It's hard to see in pictures.
    I broke the oil feed line connection to the supercharger. Where can I find a new one? Just contact vortech?
    The oil return is just going back to the dipstick? My dipstick had a port that was hooked to the oem check valve thing under the intake. Can I just drain into that?
    What size and type of fitting do I need for that oil return line? There's several holes with plugs along the bottom of the unit, just use whichever is most convenient?
    Thanks.
  1. E36 Complete e36 m3 Dinan supercharger kit
    By TLY in forum Forced & Chemical Induction Parts
    Last Post: 03-20-2014, 11:38 AM
  2. E36 E36 M3 Dinan Supercharger Kit - COMPLETE - Vortech V2 T-Trim - 10psi CARB LEGAL
    By nate325 in forum Forced & Chemical Induction Parts
    Last Post: 07-14-2013, 08:01 AM
  3. E36 M3 Dinan supercharger
    By brentbrent83 in forum Forced Induction
    Last Post: 10-08-2007, 10:12 PM
  4. Yet another E36 M3 track build...
    By Sites in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-03-2007, 08:47 PM
  5. Replies: 89
    Last Post: 05-12-2004, 02:29 PM
