Results 1 to 25 of 73
Thread: yet another E36 M3 Dinan supercharger install
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I guess this is my kickoff, Bought the M3/4/5.
    I've acquired what appears
    * Dinan Supercharger V2
    * RMS aftercooler.
    * 6" & 3ish”pullies (guessing 9-11psi)
    * Porsche MAF
    * 42lb injectors
    Still Saving for the following
    * Electric Fan
    * ECM tune
    for now I'm just going through the VF and Dinan installation instructions and getting a shopping list together.
    http://www.sportscarguyspeaks.com/20...it-begins.html
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Boston, MA
    E36 M3 Turbo
    M345 is where it's at
    Let's see what it looks like!
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I've not yet learned how to post photos very well, here goes.
    Check the plates, I'm so proud
    Is this really the bracket I need???
    Question people: I'm trying to figure out why I need a VF or Dinan front manifold support bracket.
    Both sets of instructions say to “discard the the OEM front support” then step 17. Install the replacement intake manifold support bracket in the original location
    But I have no idea a how modified it really is because there is not photo.
    VF says I need the part pictured below, which would be fine, but they didn't sound very confident so before I pay $85 I thought i'd inquire with people who have done it.
    Attachment 622770
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    Plenty of people don’t use either intake manifold support bracket—there are 2 but I would fit at least 1 if you can. I lean on the intake sometimes while working on the car. You have a Dinan kit with rms intercooler so I don’t know which you need. I think so just removed the front (towards the front of car) support. As I recall, that may make room for relocating the PS reservoir. You don’t need to buy anything.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Thanks. I’ll save my $
    Sent from my iPhone using Tapatalk Pro
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Good new $85 saved for other things
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Cool
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Next Question. What is this? I'd guess its a cheap check valve of some kind? It is missing from my pile of stuff and need to order one.
    Mar 2012
    Denver, CO
    1989 BMW 325is
    Nice another SC e36 in Colorado! I'm wrapping up my Dinan stage 1 install on my 95 m3. Your last picture is an inline filter for the CCV system. You should look into running a s62 oil separator there instead. Seems to be a better setup. This tread has a little info on the CCV setup. https://www.bimmerforums.com/forum/s...-Control-Valve
    Jun 2005
    Concord, NH
    The filter is just a fuel filter but I forget the application. You need one you can modify to the hose diameter. But most of us deleted that as noted above and went to a catch can.
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    Just a warning that pulley config will likely result in the backside of the belt rubbing against the center shaft of the s/c belt tensioner. You can see here where I clearanced it and it needs even more.
    Get rid of all that filter and valve crap Dinan uses. Plug the manifold side oil separator port and run an S62 oil separator or something like this catch can I made. Both drain back to the oil pan and do not vent to atmostphere. (can is yet to be powdercoated to match the Dinan pipes and the hoses are just temporary till I find something nicer)
    If you're missing anything hit me up. I have most all the parts for Dinan kits.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Quote Originally Posted by Braymond141 View Post
    Thanks. I like what you’ve done there
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    In your first pic you seem to be missing the rear charger bracket brace.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Yep another part I’m missing.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Questions:
    1. How is that catch a can solution better that the Dinan crap, or just more attractive?
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    The Dinan valves are known to fail. When it goes wrong you’ll suck all of the oil out of your pan into the motor. Under normal operation their solution also doesn’t keep oil out of the intake. A proper catch can is one of the only ways.
    Jun 2005
    Concord, NH
    The Dinan valve is a Ford part. I had a Dinan kit years ago and remember tracking down that 3 way valve. But I agree with going to a baffled catch can. The Burger is very good.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Looks like I'll be going with a bracket and a catch can from braymond141 once I embezzle some money from my family
    Jun 2005
    Concord, NH
    He does the Dinan system very nicely. He should come up with an Intercooler kit and tune.
    Toronto, Ontario
    boosted M3's
    Hey braymond141 what bypass valve do you use?
    I'd like to ask you about pulley sizes too if you dont mind
    glad to see people still running these setups!
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    Quote Originally Posted by ColdshotM3 View Post
    Kayser 06A145710N
    Standard pulleys.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I don’t really want 11psi on a car w/out a new head gasket and some other enhancements. So if anyone wants to swap pulley setups message me.
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    I have new Vortech 3.64 pulley
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Wanna swap for a 3.5” ?? Where you think my boost will be with my 6” crank pulley?
    Ill hit you up for a bracket too
  1. E36 Complete e36 m3 Dinan supercharger kit
    By TLY in forum Forced & Chemical Induction Parts
    Last Post: 03-20-2014, 12:38 PM
  2. E36 E36 M3 Dinan Supercharger Kit - COMPLETE - Vortech V2 T-Trim - 10psi CARB LEGAL
    By nate325 in forum Forced & Chemical Induction Parts
    Last Post: 07-14-2013, 09:01 AM
  3. E36 M3 Dinan supercharger
    By brentbrent83 in forum Forced Induction
    Last Post: 10-08-2007, 11:12 PM
  4. Yet another E36 M3 track build...
    By Sites in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-03-2007, 09:47 PM
  5. Parting out a E36 M3 Dinan ! Supercharger/Stage3 Suspension/BBS Rims/Dinan Brake Duct
    By bmwm3parts in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 05-12-2004, 03:29 PM
