Hello.
In the past, I have tried to connect to both DME's using INPA...in ODB Mode and ADS mode with no success.
Has anyone been successful in using INPA in ADS on a v12?
If you have been successful, I would like to know the following.
What version of INPA...or any other program for that matter were you successful with?
What cable did you use?
I have tried every version of INPA I could find.
Laptop. IBM think Pad with serial port
Thank You
INPA wont read those DME's. You need to use DIS.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
your cable should be ok. either of the 2 common versions of DIS that are floating around will work.
Its best to run it in a virtual machine.
Current:
