Results 1 to 6 of 6
Thread: No power to starter after impact... Help...
    Feb 2018
    Tampa, FL
    1987 BMW 325e
    87' 325e - Help please... Front driver's side collision. Other than front drivers side damage, head light assembly, undercarriage, and front bumper, it looks good. I have power to everything except the starter... is there a kill switch? It was running when after the wreck but of course i turned it off. And i can't get it to start again. I've owned her for 17 years and just started working on her myself in the last 3 but i have to get it corrected before Florida tries to total the title...
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Is your engine ground strap intact?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    maybe the starter is dead? what does the car do when you turn the key? does the start turn the motor over or nothing happens? if nothing, pull the starter and have it checked
    No e30s again.
    Feb 2018
    Tampa, FL
    1987 BMW 325e
    Not sure? Where is that located? The ground strap, I mean
    The car doesn’t turn over at all when I turn the ignition. Would the impact have killed it? I think I replaced it last year... 🤔
    Sep 2014
    Minnesota
    E21 323i, E36 M3
    Quote Originally Posted by RedheadE30lover View Post
    The car doesn’t turn over at all when I turn the ignition. Would the impact have killed it? I think I replaced it last year... 樂
    It connects one of the motor mount arms to the unibody. Without that, your starter doesn't have a connection to the battery.
    Dec 2005
    No e30s, again :(
    You can put a jumper cable from the intake to a fender or body bolt to test if the ground strap is not connected, or broken. Just clamp from some part od the enginy to the body, metal to metal and no paint on body side.
    Also, check all your fuses and that fusible link in the back, on the power line from the battery
  1. Replies: 2
    Last Post: 08-17-2011, 03:36 PM
  2. No power to fuel pump... plz help
    By mpr3ssiv in forum 1992 - 1999 M3 (E36)
    Last Post: 06-02-2011, 05:43 PM
  3. No power to fuel pump - Need help - whats wrong
    By DupaHead in forum 1992 - 1999 M3 (E36)
    Last Post: 09-30-2009, 09:20 AM
  4. no aux fan no power to fuse 75 please help
    By intvic18t in forum 1996 - 2003 (E39)
    Last Post: 01-25-2009, 08:53 PM
  5. 740i wont crank,no power to starter?
    By fixer828 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-27-2007, 11:34 PM
