This is my second set of main bearings that I have ordered that have defects straight out of the box...
I originally ordered KING BEARINGS ... rods and mains. The rod bearings all looked good, but out of the 12 mains...4 came with some pretty nasty "nicks" or imperfections that can be felt by the finger nail.
IMG_6783
IMG_6784
So last week I forfeited my Saturday plans to get the bottom end buttoned up...and ordered GLYCO main bearing set from BavAuto (they had them in stock and could get them to me by this weekend...
Now one of these GLYCO thrust/main bearings have some imperfections also, that you can easily catch or feel with your finger nail....
IMG_6858
IMG_6861
Am I being hypercritical, from everything that I have read...FM and imperfections in new bearings can cause havoc on a bottom-end....?
Should I order another set and hope that they will be right?
They call me Spaz
-1990 535i/5 with some stuff ----->M30 Turbo Build
-1996 328i sedan (S-52'd) 5-speed ----------> Refurbish Project (Wife's new DD) ---> (S52-swap)
I don't think so. What brand are these bearings? The first set looked damaged, these look like poor plating.
My engine building experience is with domestic V-8s, I've never had problems like this in many years using the common U.S.A. brands of bearings.
I would return them. I wouldn't be comfortable using them in that condition.
The first set was KING bearings (made in Israel)..
The second set was GLYCO... I am having trouble finding standard size bearings for an M30b35 that aren't a 1 month lead time. Do you know of a better vendor to do through... these GLYCO's were ordered from BavAuto, but Pelican Parts also has these exact bearings...
Thanks for your help on this
In contact with BavAuto as we speak, thank you for your input. Would BMW oem bearings be the way to go with this?
They call me Spaz
I would go with OEM if they're available. I've never done main bearings, but have done plenty of sets of rod bearings. Never had one damaged.
I thought Kolbenschmidt were the ones to get. I wonder how those stack up.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
When going for OEM bearings, make sure you get the correct size and cap colours
C217 S63 AMG S Cabriolet ( Daily )
E87 116i with mild cams, headers, cold air intake making 136 bhp Lol (My Learning Track Car)
E36 328i Sport ( Project in making and future race/track car )
The only trouble with ordering the bearings from the dealership is that each bearing HALF will cost you about the same as a complete set of Glycos. However, I've had Glycos be incorrect, on several occasions, although they were the correct part number.. Make absolutely sure that you carefully check clearances with Plastigage !
Chris Powell
BMWCCA 274412
Clevite/Mahle sells the rods, CB809P in standard and +.25mm, their catalog doesn't show the mains.
Rock Auto sells "ITM engine components" brand, can't be any worse than what you've been getting and dirt cheap.
I'd be looking for a domestic brand or OE if you need them quick
here is Kolbenschmidt catalog https://mam.rheinmetall-automotive.c...10123b9a60512c
Try king race again..
Oil pump went bang and spun bearings
Update...
I went ahead and contacted BavAuto, their customer service is great. I also ordered another set of GLYCO mains from them as they had another set on shelf.
My plan is to pick through the two sets of GLYCO mains and select the best without imperfections then plastigage everything. I will then send back the assembled damaged set of GLYCO to BavAuto for the refund.
I will update when the new (2nd set) of Glyco mains arrive this week. I appreciate all of the input and help.
Cheers,
Caleb
They call me Spaz
