Results 1 to 3 of 3
Thread: Master cylinder faulty?
    May 2016
    UK
    01/1992 E32 735i SE
    I lost brake pressure the other day so thought it's time to do the rear discs and pads as the car has been asking for a while.
    I've just noticed leaking brake fluid from between the reservoir and cylinder. The seals between the reservoir and cylinder have perished and I will be collecting new ones from bmw tomorrow.
    I'm just wondering could the actual cylinder be faulty or are perished seals enough to cause this sort of leak?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Usually just the 2 plugs 34311163464, if you are lucky. If you lost brake pressure, then maybe the expansion tank was completely empty and air came into the brake system.
    May 2016
    UK
    01/1992 E32 735i SE
    I did the rear discs, pads and replaced the two plugs on the reservoir. I have a brake fluid bleeding/flushing tool which connects to the reservoir and replaces old fluid with new as each calliper is bled but for some reason this device wouldn't work even though it had a pressure of 28psi. So will have to flush the fluid when I have an assistant
  1. Clutch master cylinder replacement!@#
    By mrhmmhmm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-10-2007, 10:26 PM
  2. E36 M3 master cylinder...where to buy?
    By GR8 Ride in forum 1992 - 1999 M3 (E36)
    Last Post: 10-28-2002, 01:57 PM
  3. replacing master cylinder
    By psk145 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-18-2002, 11:50 PM
  4. Brake Master cylinder diameter
    By robepa in forum 1992 - 1999 M3 (E36)
    Last Post: 02-21-2002, 12:17 PM
  5. Symptoms of a bad clutch Master cylinder?
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 02-09-2002, 09:57 PM
