Results 1 to 6 of 6
Thread: Help Determining Leak...
    Nov 2016
    orchard park, NY
    04' 330xi
    95' 525i. Kind of concerning haha. I have tested the head and it passed. I changed the water pump and thermostat about a month ago. Ive had to bleed it 1-2 times since then, due to overheating. Every time, just air. No more overheating (hopefully) but now these spots under the front passenger side of the car. Oil cap and dipstick are clean. Also it is very cold here this time of year, if that adds any value. Any ideas? Thanks
    Great White North
    various
    Ok George. We are going to need a few more details in order to help.
    1. Model and year of car
    2. What work has been done? New head gasket?
    3. Is your coolant level dropping? I.E. leaking onto your driveway? If so from where.
    4. How was the head tested?
    5. Anything else relevant?
    Nov 2016
    orchard park, NY
    04' 330xi
    I did answer a majority of those questions in the OP. 95' 525i. No new head gasket to my knowledge. I tested with one of the combustion testers with the dye. Didn't change color. No coolant level drops. front passenger side.
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Maybe a crack in your radiator or a hose? You could use a coolant UV dye to trace the leak, if you haven't done so.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by moroza View Post
    Why speculate? Lift it and look.
    This^
    Also those spots look to me like oil that has been dropped on a wet surface or seen condensation form on it, not coolant.
  1. help determining coolant leak
    By richpngu in forum 1996 - 2003 (E39)
    Last Post: 07-18-2013, 12:22 PM
  2. Help!! Car leaking OIL!!
    By Wasiq in forum 1991 - 1999 (E36)
    Last Post: 04-20-2004, 11:48 AM
  3. help... coolant leaking from expansion tank cap
    By shhuang in forum 1991 - 1999 (E36)
    Last Post: 03-22-2004, 11:01 PM
  4. HELP! Water leaking inside car...
    By TireFryer in forum 1996 - 2003 (E39)
    Last Post: 08-26-2003, 11:17 AM
  5. For All You Auto-X'ers Out There......I Need Help Determining My Class With My Mods
    By jmciver in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-27-2002, 02:43 AM
