Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 52
Thread: Coolant and no heat!
  1. #26
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    I was wondering if anybody has a good drawing of how the vacuum lines are supposed to run. I think im missing a line. So here goes. Looking at the motor, there is a line onthe left side that turns into a hard plastic ine that then connects to another hard that goes under the car, but on the secondary pump on the firewall side of the intake, there another barb fitting on that pump that isnt hooked up...so anyways any help would be helpful. I dont want to take this intake back off if i dont have to....
  2. #27
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    This is the vacuum diagram for the SAP, and #5 sits on the firewall IIRC: http://www.realoem.com/bmw/enUS/show...diagId=11_2203
    Now you have another vacuum line that goes to the Fuel pressure regulator: http://www.realoem.com/bmw/enUS/show...diagId=13_0737
    And this is the fuel tank vent line: http://www.realoem.com/bmw/enUS/show...diagId=13_0633
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  3. #28
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Where is the fuel reg? It lists a line but doesnt show where it goes...so would that be the hard line that runs under the car??
  4. #29
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Or i guess where does it go in the engine compt??
  5. #30
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Ok, still not getting ir....so i have the line that runs from the front left side motor to the sap which l have hooked up then i have a plastic hsrd line that runs under the vehicle, and i dont have a clue what that is.whether its a tank or fuel psi.
    I would like to get this taken care of so i can put my intake on...
  6. #31
    dworthy's Avatar
    Nov 2010
    Yes, there is a hardline that runs down to the FPR, and the FPR is located down by the frame.
    Darin
    Current:
    Past:
    M-Flight Member
  7. #32
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    And where does it go in the engine compt?
  8. #33
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Ok, let me explain, so on the FPR sheet that you sent, its line item 8 i understand where the line plugs into the FPR, but where does the other end go?
  9. #34
    dworthy's Avatar
    Nov 2010
    The line should go up into the engine compartment and connect to another soft line. That soft line should connect to the intake near the throttle body IIRC. On the older BMW's you will have a seperate fuel filter, and the FPR will be under a cover with it.
    Darin
    Current:
    Past:
    M-Flight Member
  10. #35
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Thanks Darin For all your help. Ill check it out tonight..
    Again Thanks...
    Craig
  11. #36
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    So here is a scenario: Start car...drive car..temp gauge is 12 noon in 8 minutes...Turn on heat...temp gauge drops to halfway on the temp gauge then slowly graduates back to 12 o'clock....now good for the rest of the day...................And yes..I am quite stupid...but as a weakling...I need your help....
  12. #37
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Ok, what i have found is a barb in the intake manifold that was pluggedl and a barb in the CCV...notthing around the throttle body...
    Help please....
  13. #38
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Please read down to the bottom thanks!!
  14. #39
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    So i think i have it figured out..the only one i dont is the barb on the CCV. Do I need to plug that one??
  15. #40
    Mar 2016
    Flowery Branch, GA
    2000 323i
    Quote Originally Posted by craigd4937 View Post
    On my 323i, there is a hard metal vacuum line built into the fuel rail. Do you have that? If so I believe the hard line from the fpr plugs into a 1/8" rubber hose that connects to the fuel rail nearest the firewall. Then you should have the other end of the metal vacuum line connecting into another 1/8" rubber hose that goes under the intake manifold and connects to the barb on the ccv.
    Sent from my LGLS992 using Tapatalk
  16. #41
    dworthy's Avatar
    Nov 2010
    No, the CCV doesn't need the additional hose, but it is a good idea if you are using more than a quart every 1k-2k miles.
    I would have to crawl into the wife's car to see where exactly those line run into, as she doesn't have the one for the SAP.
    Darin
    Current:
    Past:
    M-Flight Member
  17. #42
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Yes, I do have that metal line on the fuel rail, So it looks like the front end of that goes to the ccv and the rear goes to the fpr. and then the vacuum line that runs from the front of the engine to the svp on the rear of the intake...so I think that we have figured it out.
    Thanks for all your help....
    Craig
  18. #43
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Extra Parts
    Well, almost put back together and all of the sudden found two of these...does anybody know what these are????
  19. #44
    dworthy's Avatar
    Nov 2010
    I wish I could help, but I haven't or cannot ever remember seeing that part, sorry.
    Is there any numbers on it?
    Darin
    Current:
    Past:
    M-Flight Member
  20. #45
    Mar 2016
    Flowery Branch, GA
    2000 323i
    Those are parts of the intake manifold. You would need to remove it and put them in. They belong on the bottom where the rubber gasket is. You may have a vacuum leak without them as the gasket may not be seated correctly without it.
  21. #46
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    How many are there? and explain where they go again? on the bottom where the gasket is? If I turn it over will it e obvious where they go??? thanks for the info Ken!
  22. #47
    Mar 2016
    Flowery Branch, GA
    2000 323i
    It will be obvious. They fit like a puzzle. The circular part of the O ring goes around the circlular edge.
  23. #48
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Still not seeing it....where are they close to?? And i only have two....
  24. #49
    Mar 2016
    Flowery Branch, GA
    2000 323i
    Do you have the intake manifold out? Have you removed the gasket? If so you should be able to fit them into the intake manifold like a puzzle. I wish I could explain it better. I don't know what they are or what they do, I just remember seeing one fall out when I had my intake out. I will look online and see if I can find some pictures.
  25. #50
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Yes i have it back out but havent removed the gasket, will remove it today and see maybe where they go....
  1. Leaking coolant..now car overheating?and no heat?
    By m.dystynkt.m in forum 1999 - 2006 (E46)
    Last Post: 01-19-2008, 05:18 PM
  2. Coolant Leaking and no heat after flush
    By amdspitfire in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-11-2004, 12:02 AM
  3. Coolant Leaking and no heat after flush
    By amdspitfire in forum 1991 - 1999 (E36)
    Last Post: 11-14-2004, 04:40 PM
  4. cooling problem and no heat from heater in 325
    By BooDaddy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-05-2004, 09:44 PM
  5. chirping alternator and no heat at idle
    By FLiPModE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-13-2002, 03:38 PM
