Results 1 to 6 of 6
Thread: Shifter/Selector Rod Joint pin not coming out???
    Jan 2005
    Wisconsin
    1992 bmw325i
    Trying to replace the selector rod joint on my 99M3 before I starting re-installing shifter and what not. I have removed the clip off the rod joint itself but the pin will not punch out at all to be able to remove it. Any tricks to getting the pin out? should just slide right out I assume. I tried using a punch and tap in out upwards towards the trans tunnel but it doesn't budge. Any help is much appreciated. First time really doing anything like this. Thanks guys.
    Jan 2005
    Wisconsin
    1992 bmw325i
    Also that seal that is at the rod joint seems to be leaking as well. I found the DIY to replace this seal. Looks like most guys have pried the seal out with a flat head and pressed the new seal in with a deep 15mm socket. Sound about right?
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Yes, that is how the shift selector rod seal is replaced... just did mine when installing a new DSSR from Garagistic. Selector rod pin comes right out once the pin is removed....
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    Jan 2005
    Wisconsin
    1992 bmw325i
    The Pin is frozen in there. It should slide right out but doesn't want to. I tried wiggling it and applying pressure towards the transmission as well, but nothing.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Smaller punch? Penetrating spray?
    Jan 2005
    Wisconsin
    1992 bmw325i
    Finally got it out. I had to pound the piss out of it and finally came. Now just waiting on the seal from bmw to come in and I should be good to go. Thanks for help and DIY link to seal
  1. Replies: 24
    Last Post: 07-08-2009, 05:23 PM
  2. E36 control atm problem... outer ball joint not coming out
    By GreyMethod in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-12-2008, 09:56 AM
  3. E36 M3 SHIFTER & SELECTOR ROD $100 SHIPPED FOR 318,325ETC
    By BRUNO in forum BMW Parts For Sale
    Last Post: 12-11-2004, 07:29 PM
  4. Gear Selector Rod Joint
    By ca415playa in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2003, 09:29 PM
  5. 95 M3 Glovebox will not come out
    By GQ_Style in forum 1992 - 1999 M3 (E36)
    Last Post: 11-18-2002, 09:13 PM
