Results 1 to 9 of 9
Thread: creaking steering
    Jan 2018
    Sachse, TX
    several
    creaking steering
    Any idea what this might be? Possibly just started with cold weather. Not sure.
    Sent from my SM-G930V using Tapatalk
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Mar 2005
    italy
    Z3 M44 roadster 1997
    what d'you mean with "creaking"? explain further
    miss ZUKU!
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by resunoiz View Post
    Creaking when turning the wheel. Seems to only be when cold. Doing okay as it has been warmer.
    Jeremy
    Boston
    04 330i zhp; 06 Cooper S
    If it creaks when you first turn the wheel, that could be the steering guibo, which is a rubber coupler in the column.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by maxell0405 View Post
    How easy is that to change?
    Jeremy
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    The more useful question is WHERE is it squeaking... in the car or under the hood... then we can make useful suggestions.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    If its creaking under the hood only when cold, then chances are its the strut mounts.
    Mar 2005
    italy
    had this issue on E36/7. Was the plastic assembly that aging and wearing&tearing started to crack.
    I removed the steering, and sprayed a little wd-40 on the plastic assembly and moving parts. never heard any more noises from there.
    Maybe is the first thing to try, no cost and zero efforts. Take care of electric parts: wd-40 is not dangerous but to be sure leave it pristine.
    miss ZUKU!
    Jan 2018
    Sachse, TX
    several
    Thank you! Will look into this.
    Jeremy
  1. Creaking steering wheel...... What can I do?
    By tsouzee in forum 1996 - 2003 (E39)
    Last Post: 12-07-2008, 11:34 PM
  2. Creaking Steering?
    By Low Level in forum 1991 - 1999 (E36)
    Last Post: 07-01-2008, 03:05 AM
  3. Anybody have a creaking steering wheel?
    By Al's540i in forum 1996 - 2003 (E39)
    Last Post: 09-24-2007, 03:46 PM
  4. Creaking Steering wheel?
    By lotusTT in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-10-2006, 05:25 PM
  5. Creaking Steering Wheel - 523i SE
    By kailesh in forum 1996 - 2003 (E39)
    Last Post: 03-29-2006, 05:41 PM
