Results 1 to 8 of 8
Thread: Dash display
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    Dash display
    I got home and shut off my car, 95 525i 5 speed. The message screen on the dash went crazy. I took a short video.
    https://youtu.be/EKTVAJme0Jo
    Any idea what's going on?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Dead pixel are very common, but that is the first I have seen. What I would do is make sure all the connectors are clean and seated on the back, and it wouldn't be a bad idea to pull the instrument cluster apart and have a look there as well.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    NW suburban Chicago
    hiss by my window
    The capacitors on that cluster sometimes fail, it's reasonably common at this age.
    Not sure if this is one of the failure modes.
    I've suggested moving your thread to the E34 sub-forum where there are more members familiar with your model.
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    yup, i've run across this before on an e34. in fact, my e34 did almost this exact thing. i replaced the cluster board with a refurbished one from programa (i think that's the place) and that fixed the problem.
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    As far as I can tell, it's working as of the next time I drove the car.
    Mar 2003
    St. Joseph, Mo.
    same thing mine did when i had an e34.
    Colorado
    93 E34 slushbox
    Quote Originally Posted by ChrisSilva View Post
    capacitors are going out. It will work or not work depending on the temperature. IIRC, mine worked when cold but would malfunction as the capacitors heated up and lost their functionality. Dont be surprised if it becomes more common as the year wears on.
    93 E34 525I Slushbox
    83 GMC C1500
    84 GMC K3500 3+3
    10 Subaru Impreza w/ hail damage
    Feb 2013
    Burlington, Ontario
    1991 750iL+ 2008 535xit6
    Quote Originally Posted by affende View Post
    Capacitors don't go bad nearly as often on 1995s--and if they do, it's a work/notwork issue, not a "works weird" issue.
    Solution: I had this exact same problem with mine. A replacement LCD (used in my case) display cured it. The original had some corrosion on some of the solder points, and was worse when hot.
  1. FS: STACK ST800 dash display
    By m3ltw98 in forum BMW Parts For Sale
    Last Post: 12-11-2004, 03:35 PM
  2. FS: STACK ST800 dash display
    By m3ltw98 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-10-2004, 09:21 AM
  3. Replies: 0
    Last Post: 11-01-2004, 07:26 PM
  4. Aquamist Dash Display
    By BP SCM3 in forum Forced Induction
    Last Post: 05-29-2002, 09:24 PM
  5. Changing the Dash Display lights
    By M3Newbie in forum 1991 - 1999 (E36)
    Last Post: 05-27-2001, 12:01 AM
