Results 1 to 25 of 42
Thread: 1998 750il M73 - Slow Acceleration
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Recently acquired a 1998 750il with 70k miles. The car was garaged for 18 years, then outside for the last 2 years. Upon purchase one DME was on the back seat and had been painted black. Using progman I recoded the DME's and Encoded a new EML from a donor. My EML was laden with codes. I also replaced one throttle body that was causing engine failsafe due to mechanical failure. I replaced the fuel filter, pumped out a gallon of gas via relay jump, then added 5 gallons of premium, octane boost and seafoam.
    Temp gauge is not working either. Works in cluster test though..
    The car now runs and idles but takes 30 seconds to reach 60mph. One crank case valve is sucking air, so that is on order. I've had that issue before on a previous 750, so Im positive its not causing the slowness Im feeling.
    INPA Codes to decipher a starting place:
    108 "unterbrechung Dauerversorgung" = Voltage Supply B+, Battery Voltage (battery is brand new)
    140 "motormoment bankvergleich" = Engine Torque - Bank Comparison <----Where do I start?
    21 Ultrasonic sensor front right (wheel sensor?)
    and some EWS codes
    204
    39
    Here's a video showing firsthand sluggishness.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    Kansas City, MO
    2x01 750, 01 740
    Only running on one bank? Try replacing both coils if you have spares.
    See my E38 parts for sale on eBay: click here!
    PM me here for a 5% discount on any of them!
    Nov 2016
    Germany
    BMW E38 750IL Facelift
    it must be a throttle body problem try to reset the adaption of the throttle bodys with DIS.
    Mar 2011
    Greenville, NC
    I will take that into consideration. I dont have a spare coil, but if I need to nab one to help solve this I will.
    Thank you both for the input!
    2001
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That's slug slow! Yes, only running on one bank by the sound of it - but rather than guessing use diagnostics:
    http://www.meeknet.co.uk/E38/Diagnostics.htm
    My BMW Repair YouTube Channel
    Mar 2011
    Greenville, NC
    That is a great site! Thank you 1000 times for putting it together.
    2001
    Mar 2011
    Greenville, NC
    Im away from the car right now, but correct me if Im wrong. The M73 has true dual exhaust right? I did feel the exhaust being emitted from both sides once it was cranked. Just trying to rule out running on one bank.
    Quote Originally Posted by Timm View Post
    2001
    Mar 2011
    Greenville, NC
    2001
    Mar 2011
    Greenville, NC
    2001
    Jul 2016
    San Diego
    1998 E38 750iL
    Quote Originally Posted by 740ilDuke View Post
    Mostly true dual but there is a center resonator ahead of the rear axle which allows the sides to mix somewhat. I believe the two pipes inside are perforated with insulating material between them.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, the resonator allows the gasses to mix, so you can't tell if one bank has fizzled out from the exhausts. I notice that there is a zero load measurement on the last picture - and 2.3 on the other bank - so one bank isn't running. The smoothness figures need to be taken when the engine is running - unless it was taken and the missing bank is somehow stopping the readings!
    Mar 2011
    Greenville, NC
    Crazy. That makes sense - half power.
    So I need to look a the coils to start.
    I thought it was definitely odd I wasnt getting any readings. One DME is the "master" and one the "slave" the
    way I understand it. Im just trying to logically go through this in the right order. This is my crash course on the
    M73 I suppose.
    2001
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Do you not get any error codes?
    Having a look through your diagnostic pages it looks like you are not getting the engine speed reading on one bank - and that would point towards a crankshaft sensor failure - and that often does not leave an error code!
    This is the screen shot:
    The top left slider should show the engine speed (which is generated by the crankshaft sensor)
    Mar 2011
    Greenville, NC
    I think I shared all the codes on the initial post. Is there a specific program I should use? I have Inpa, InpaQT, DIS 4.4 & 5.? etc.
    Happily there seems to be just one CPS on the V12. And its not awful to get to. So, thats now on the table. Im going up to VA where the car is
    in a couple days to start digging back in.
    Post I found on BB on how to swap CPS. http://www.bimmerboard.com/forums/posts/695769
    2001
    Kansas City, MO
    2x01 750, 01 740
    Timm said crank not cam.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    ....and a quick check on RealOEM shows that you only have one CRANKshaft sensor - so the lack of an engine speed signal on one bank is probably down to INPA rather than a lack of a signal - the engine would not run at all without the single crankshaft sensor signal. If possible, get the smoothness page back up with the engine running and show me the results...
    Kansas City, MO
    2x01 750, 01 740
    This thread is about his 1998 750. 750s have two crank sensors due to the dual DMEs.
    http://www.realoem.com/bmw/enUS/show...diagId=24_0696
    Part #11 Qty: 2
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Good, that leaves the crankshaft sensor being the most likely candidate....
    Mar 2011
    Greenville, NC
    They look easy to get to on the tranny, interesting to see how they are situated. Looking forward to checking this out!
    Quote Originally Posted by psjr View Post
    Part #11 Qty: 2
    Not sure what's up with INPA. I'll try the same program on my 740 and see whats up. Id be its not inpa - but who knows!
    2001
    Jul 2016
    Chicago, Illinois
    are slow
    Swap the sensors, standard V12 procedure when something goes wrong.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Notice that in my last post I realised that I was looking at the wrong diagram - and the V12 has two crankshaft sensors - and that leaves the highest probability that one of them is at fault
    Mar 2011
    Greenville, NC
    Got it. I see the diagram shows one at 6 oclock and one at 4-5 oclock. If they aren't overly complex to swap, I can "borrow" one from my dads 01' 750 and see how it goes. Definitely thinking its the one bank issue. Rain the next two days, attacking this Sunday all day.
    2001
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    They are held on by a single bolt and have the same connectors - you can pop them both out, swap them over and re-connect - if the problem swaps to the other bank then Bob's y'er uncle....
    Mar 2011
    Greenville, NC
    Not to sound like a fool, but is there a way to know if one bank is running or not as is? Since INPA doesn't seem to be registering.
    2001
    Jul 2016
    Chicago, Illinois
    are slow
    Do you hear six injectors ticking or do you hear 12 injectors ticking?
  1. Help needed on a 1998 750iL - M73 engine
    By TxGR8White in forum 1995 - 2001 (E38)
    Last Post: 09-02-2016, 08:21 AM
  2. 1998 750iL No acceleration
    By jmindler in forum 1995 - 2001 (E38)
    Last Post: 08-08-2013, 08:39 PM
  3. 1998 540i Slow Acceleration and Noise
    By chrisbenejam in forum 1996 - 2003 (E39)
    Last Post: 02-27-2013, 09:13 AM
  4. 1998 750il with 125k stll worth a crap or is it about to bust
    By chinaman in forum 1995 - 2001 (E38)
    Last Post: 10-10-2005, 12:53 AM
  5. 1998 750il 42k miles White on Tan 4 Sale
    By marshcorona in forum BMW Cars For Sale / Wanted
    Last Post: 09-05-2004, 03:16 PM
