1992 BMW 325I Sedan with many upgrades and race ready. Car has Nasa, SCCA, WRL, Champ Car log books. I have owned the car for 2 seasons and it has finished top three multiple time in GP2 WRL, Chump Car EC class, and Nasa.
Car has very well built cage
Car is around 2700# I haven't scaled it empty (WRL requires weight full of fuel)
m52 2.8 liter installed in mid 2017 @180 rwhp I haven't had it on a dynojet only on the engine builders dyno for tuning that typically runs a little less than a dyno jet.
Active Autowerks exhaust from headers to tail pipe 2017
M50 intake swap converted to OBD 1 2017
S54 oil filter housing 2017
baffled oil pan 2017
new oil pump and updated suction tube 2017
cold air intake 2017
bored out throttle body 2017
Miller W.A.R. chip October 2017
New alternator and fuel pump since last race in October 2017
Mishimoto Aluminum radiator, and expansion tank in 2017
Silicone radiator hoses in 2017.
Setrab oil cooler in 2017.
New all metal water pump 2017
converted to ZF 5 speed transmission
3.46 rear end in with 3 clutch with ramps LSD 2017
AIM MXL 2 High Performance Digital Dash in late 2017 has smarty Cam wiring installed, Oil Pressure, Water temp, Oil temp, RPM GPS speed, data logging, track maps, shift lights, adjustable warnings, lap timer,
water temp and oil pressure Manuel gauges
window net 2016
Simpson C5R driver net net 2017
Car has lexan rear and side windows 2016
cool suit system
Race Electronics radio wiring and holder Willing to sell radios with the car for additional money.
delrin bushings
24 gal. Pyrotect fuel cell (2016) lowered down to 19.1 gallons capacity is changeable.
TC Kline camber plates with Koni double adjustable shock and struts, re-built by True Choice Koni in 2016.
TC KLine front and rear springs. 400# front and 700 # rear
H &R 27 mm sway bar front and 29 mm rea sway bar
New wheel bearings on all four corners in 2016.
ARP wheel studs in 2016
AMB wired transponder
new kill switch 2017
Sparco Pro ADV seat on slider in 2017
Schroth Profi II harness 2017
new Fire Sense fire System in 2017
hard wire my laps transponder
2 sets on Kosei K1 17"x 8.5" wheels
1 race weekend on Frozen rotors
Car has been nut and bolted, fluids changed since last raced in October and is ready to go to the track today.
Car has many other features and aftermarket parts.
Asking $17,000. or Best Offer
218-349 -8230 ask for Andy.
[IMG]/Users/Andy/Downloads/IMG_3321 3.JPG[/IMG]
