Results 1 to 6 of 6
Thread: 94 740i bmw e32 7s trans prog error code
    Apr 2013
    bay point ,ca. 94565
    94 740i bmw
    have just cleaned trans selonoids and valve body re installed them and car is shifting but cant get trans prog error code removed what can I do or could the tcm still be a problem and is there a wy to test that
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    did you test the solenoids on the plug on the trans? Here are the specs
    11.5 MB for download, detailed information needed for valve body rebuild
    Technicians Guide
    INDEX
    ZF 4HP-18FLE AND ZF 4HP-18 FLA DIAGNOSTIC INFORMATION
    ZF 4HP-22/24 SERIES DIAGNOSTIC INFORMATION
    MODEL “E-7” VALVE BODY WITH 5 SOLENOIDS
    MODEL “E-9” VALVE BODY WITH 4 SOLENOIDS
    ZF 5HP-18 DIAGNOSTIC INFORMATION
    ZF 5HP-19FL DIAGNOSTIC INFORMATION
    ZF 5HP-24 DIAGNOSTIC INFORMATION
    ZF 5HP-30 DIAGNOSTIC INFORMATION
    http://parts-at.ru/wp-content/upload...Tech-Guide.pdf
    Also I would try a control module reset, disconnect the battery for 30 minutes and reconnect. Before doing that make sure you know all the codes for radio, anti-theft device and how to reset the OBC time and date.
    Oldham UK
    '00 330i Sprt '92 525i
    In emergency aka limp mode, you only get a high forward gear plus reverse. If it is shifting normally 1-5 + reverse, this sounds more like a spurious warning - possibly an issue with the cluster. IIRC, the TCM provides a ground to the cluster to bring up the 'trans prog' message. The wiring diagram suggests you might have a look at pin 25. No TCM fault codes?
    Apr 2013
    94 740i bmw
    740 i 7s
    No sure this is where i post answer but no there is no TCM error code just a trans program code
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Threads merged.
    Jan 2005
    Japan
    and moved to the E32 forum
  1. Replies: 6
    Last Post: 12-04-2015, 02:38 AM
  2. Trans Prog error with a difference?...
    By teenbimmer in forum 1988 - 1996 (E34)
    Last Post: 02-14-2010, 03:29 PM
  3. 1991 525i trans prog error
    By ricke5050 in forum 1988 - 1996 (E34)
    Last Post: 10-01-2009, 09:19 AM
  4. Trans Prog errors - solved
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 09-14-2009, 12:52 AM
  5. 94 740I seat motors and tran
    By waterboy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-09-2008, 09:15 PM
