Results 1 to 9 of 9
Thread: Speed
    Dec 2017
    Michigan
    1998 BMW 528i
    Speed
    Hello everyone, I have a 1998 BMW 528i automatic with 264,000 miles on it. I bought the car at 255,000 miles and I have to say I've been happy with the car so far. I had a couple of fixes and one of the most important oil pan gasket. I've been recently revving my car pretty hard and I am not so happy with the speed. My car has 1 2 3 D N R P. I once drove off with 1 then shifted to 2, then to 3, and so on. I got 10.18 seconds from 0-60. I then decided to put it on drive and just accelerate. I got 11.24 seconds. The thing that really got into my head is, when the RPMs where getting high, around 5 I could hear a like a metallic sound something like "ggggrr" or ticking, something that didn't sound right. Afterwards I never went hard on the car cause I am kind of scared of what might happened. What do you guys think I could do to be safe and go faster?
    San Jose, CA
    1997 BMW 540i 6 speed
    Take it to a BMW mechanic for an inspection.
    You should also replace the VANOS seals.
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    +1 to edjack
    To build on his recommendation, here's what needs to be done before you should depend on it for a long trip or try to push its limits: http://www.bimmerzone.com/category/T...nspection.html
    The VANOS seals can wait until the next time you change the valve cover gasket, which is notorious for plasticizing and leaking. Here's the DiY for your '98 528i, which has single VANOS: http://www.beisansystems.com/procedu..._procedure.htm
    [IMG][/IMG]
    Dec 2017
    Michigan
    1998 BMW 528i
    do you guys know what VANOS are? I tried to understand it, but my english not the greatest thing. Please someone explain me, thanks!
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    It is also called "variable valve timing" it improves engine efficiency and performance. Here are some videos: https://www.youtube.com/results?sear...y=vanos+engine
    Dec 2017
    Michigan
    1998 BMW 528i
    What's the first website About?
    San Jose, CA
    Quote Originally Posted by Antonis1210 View Post
    It describes the items that pertain to Inspections I and II.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Part #1 needs the o-rings replaced.
    http://www.realoem.com/bmw/enUS/show...diagId=11_1480
    May 2010
    Allentown, PA
    1997 528 Auto 03/'96 M52
    How are you measuring the 0-60 times? Where are you doing it (TOTALLY flat ground?)? Did you do both tests at the same exact road/starting point? Are your times a single time or did you do it 3 times and take the average?
    Just a side note... I believe the car, when new, was about an 8-second car - so I wouldn't be surprised if it was a little slower after 20 years and 1/4 million miles.
    I'm not saying anything against the VANOS recommendation as it's a valid point - just that there could be other factors. When you accelerate hard, you should feel an extra "oomph" of power somewhere around 4,000 RPMS. Do you feel that?
    Are you pushing the pedall ALL the way down - past the final "click" when you get close to the floor?
  1. Speeding tickets
    By Saul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-06-2001, 08:55 AM
  2. How to beat a speeding ticket
    By BAADDOG in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-29-2001, 10:01 PM
  3. Is there a way to buy a six speed through BMW?
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2001, 01:16 PM
  4. Top speed poll
    By gerry_miranda in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-24-2001, 10:57 PM
  5. How is the speed?
    By ray in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-28-2001, 02:03 AM
