Results 1 to 5 of 5
Thread: Alternative fuel pump rather than replace the whole assembly? M73
    UAE
    SL300-24, 750iL, 633CSi
    Hi Guys
    Whats an alternative fuel pump to replace mine rather than replace the whole assembly?
    Iv read the sticky but thats for the dual pump M70 and S70, I have the single pump M73 and im trying to avoid to fork out $500+ on the whole assembly
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
    Jul 2017
    toronto, ontario
    1991 BMW 850i
    This is probably not the solution you are looking for but maybe this info is helpful. I bought my 91 850i with what I was told was a Ford Mustang (aftermarket?) single Fuel Pump mounted externally beside the fuel filters. Original pumps were both removed. I always felt nervous and hope to one day put it back to original but to be honest, I've run it this way for over 6 years/ 50k kilometers without the slightest problem. I can't give you many details on how it is hooked up other than to say power comes off only 1 of the pump's wiring at the tank. The fuel pump's outlet goes into a t and then to the 2 original fuel lines up to the 2 fuel injector rails.
    Apr 2016
    Philadelphia
    1997 m3
    I believe the part number for just the pump would be 16 14 6 768 653 but you should double check with realoem.com by entering your last 7 of the vin.
    Many sources sell the oem pump for a reasonable price, or you can get an aftermarket one.
    Jun 2008
    TT Cayenne / SC 850
    Quote Originally Posted by spitfire980 View Post
    Hi Guys
    https://www.bimmerforums.com/forum/s...-Pump-Assembly
    UAE
    Thats the 1st thing I read! Unfortunately, mine is a single pump design. According to my research, Bosch 69493 should do the trick
  1. Replies: 14
    Last Post: 07-08-2015, 12:19 PM
  2. Replies: 9
    Last Post: 08-18-2013, 03:56 AM
  3. Replies: 8
    Last Post: 02-25-2005, 10:45 AM
  4. Fuel pump wired directly to the battery?
    By rollinwardle in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-23-2005, 12:10 PM
  5. Cracked foglight lens - do I have to replace the whole light?
    By John V in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2004, 07:17 PM
