Results 1 to 17 of 17
Thread: Right trunk tail light has a possible short
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    The right light on my trunk doesnít come on unless I hit the trunk or open and close it really fast. Like shaking it while itís open basically. Is this likely a problem with the light itself?
    Mar 2006
    Harrisburg, PA, USA
    x5, 750i, 850Ci, 850CSi
    Quote Originally Posted by killian665 View Post
    The right light on my trunk doesn’t come on unless I hit the trunk or open and close it really fast. Like shaking it while it’s open basically. Is this likely a probablem with the light itself?
    My guess would be a short in the cable loom.
    Mike Barrett
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    Canada
    95 BMW 850
    The right light on the trunk lid may be close to burning out. I had the same problem, (when the engine is on all four tail lights are on), and if I hit the right trunk light it would turn on until it wouldn't anymore. Dealer replaced the bulb. It took only a few minutes.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Guess Iíll pop it out and see
    Mar 2008
    montreal,Canada
    bmw 850
    i had problems with my right tail light' it turned out to be a short in the plug itself.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Burnt wire? Loose connection? Howíd you fix it
    Laguna Woods, California
    1993 850Ci, 2011 Nitro
    Burnt wire? Loose connection? How’d you fix it
    Turned to be a broken wire in the harness in the trunk lid. During a "mini" Wrenchfest last year a SocalEights member with the patience of "Job" spliced the broken wire and it's been as good as new since.
    1993 850Ci.....160,000 miles and counting!
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Timm has a fix up for this under the DIY section.
    In my opinion, the only way to really fix this long term is to cut out and replace the entire wiring section that is between each set of grommets. That is more involved, but ENGL sells a decent kit. Special crimping tool is needed however.
    What "thumbs up" really means
    Nov 2008
    NYC
    850x2-M5-CLS-LotusS4-ZR1
    Link?
    Quote Originally Posted by toomanyparts View Post
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's the link:
    http://www.meeknet.co.uk/e31/BMW_E31...ing_Repair.htm
    .....but your fault sounds more like a failing bulb than a hinge wiring problem.....
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Iím starting to think it might be more I donít know. My under hood and interior trunk lights also donít work and I just now put new bulbs in them. Must be a wiring problem somewhere even if itís not related
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Okay yeah, all 3 of my interior trunk lights donít work. The two in the trunk lid itself that are part of the actual taillights and the one in the car under the rear deck. The under hood light also doesnít work. All new bulbs
    *Update*
    My underhood light only comes on when I have the hood open and I turn the headlight switch either to the middle or full on. Is that normal? I feel like it should just come on when the hood is open regardless.
    Also I believe it is the wiring at the hinge because I can get my trunk lights to come on at an exact spot when opening then they go off if itís higher than that point. I didnít think the light under the rear deck on the body itself was part of that same loom as the ones in the trunk lid that shine down, why would that be affected?
    Mar 2006
    Harrisburg, PA, USA
    Okay yeah, all 3 of my interior trunk lights don’t work. The two in the trunk lid itself that are part of the actual taillights and the one in the car under the rear deck. The under hood light also doesn’t work. All new bulbs
    *Update*
    Also I believe it is the wiring at the hinge because I can get my trunk lights to come on at an exact spot when opening then they go off if it’s higher than that point. I didn’t think the light under the rear deck on the body itself was part of that same loom as the ones in the trunk lid that shine down, why would that be affected?
    That's the way the underhood lamp is supposed to work.
    Mike Barrett
    Mike Barrett
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    What a dumb design haha. Well I guess that narrows it down to the harness then. Guess Iíll pull the whole thing out of the trunk lid and see whatís going on.
    Mar 2011
    Quote Originally Posted by G8nightman View Post
    Link?
    http://www.engl-production.de/heckklappenkabelsatz.html
    Need some proper crimpers, Greenlee Crimp-all comes to mind. Will need to check the die number.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yeah those are the factory bmw repair connections. I have the crimpers for those so thatíll work nice, thanks.
    That website sucks how do you even buy stuff
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Okay good talk
  1. E39 FS OEM 5 series e39 right, passenger tail light
    By sharksfan in forum Exterior Lighting & Body Parts
    Last Post: 03-04-2011, 12:45 PM
  2. right side tail light for sale
    By billyr3d in forum Z3 (E36/7, E36/8)
    Last Post: 12-09-2006, 10:12 PM
  3. WTB: E34 Right Outer Tail Light
    By Kdog2112 in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 08-03-2006, 02:09 PM
  4. Water in Trunk, Tail light failure on OBC
    By Ubertino in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-14-2005, 03:34 PM
  5. Trunk Tail Lights
    By nocalbmw in forum 1996 - 2003 (E39)
    Last Post: 03-28-2005, 07:01 PM
