Results 1 to 14 of 14
Thread: Temp Sensor
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Temp Sensor
    While replacing some old air intake boots I found two different intake temperature sensors. One of them had the wires cut while the other seemed to be properly connected. I know the car was in a front end collison at some point and wondering if the cut one is from replacement intake box? Can anyone tell me 1) is there only disposed to be one temp sensor? 2) which is the correct one?
    Also, my OBC temp does work.
    Thanks.
    Nov 2014
    Stockholm, Sweden
    1992 BMW 850
    Quote Originally Posted by nrp22101 View Post
    Thanks.
    As I remember it should be 2, one for instrument cluster and one for dme's.
    Skickat från min Nexus 5X via Tapatalk
    Nov 2014
    Stockholm, Sweden
    1992 BMW 850
    Quote Originally Posted by Captenkaos View Post
    I'm talking about 850, I don't know about 840.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    On the M70 of my E32 750
    air intake temp. sensors are inside the MAF , Nr. 1 shown here http://bmwe32.masscom.net/sean750/MA...leshooting.htm
    and 2 at the back of the intake as shown here, 1 each side http://bmwe32.masscom.net/sean750/sp...enumIntake.jpg
    then there are 3 coolant temp sensors on the back of the engine
    On my 750 M70 there are from right side to center
    ECT = engine coolant temperature sensor on M70 engine is at the right rear of engine in coolant cross pipe, 3-pins
    That goes to the both DME, brown/red wire and ground to DME 1, brown/red/yellow wire and ground to DME 2.
    Testing data are in the Bentley repair Manual page 130-35
    left one >>temperature gauge sender
    right one>> engine coolant temperature (ECT) sensor (DME)
    middle one>>>EML coolant temperature sensor
    Location: in coolant crosspipe at rear of engine under the coolant expansion tank.
    The open circuit supply to the sensor is at a 5.0 volt reference level and this voltage reduces to a value that depends upon the resistance of the CTS resistance. Normal operating temperature is usually from 80° to 100° C.
    The ECU uses the CTS signal as a main correction factor when calculating ignition timing and injection duration.
    EML introduction http://www.europeantransmission.com/...MWtechinfo.htm
    1 is 5 Kohm
    you can double check that in the Bentley repair Manual page 130-35, here are the ohms at different temperatures http://www.e32-schrauber.de/bmw/s-tempsensor.htm
    use realoem.com, search for the part numbers and then google search with it for data
    08 Engine coolant temp sensor 2-POL 12621710535 outside , internet shows 5kohm . 12 V, M14x1,5, Hella coolant -Sensor 6PT 009 107-471
    07 Temperature sensor, water M14X1,5 12621288158 middle 20 deg. C, 2500 Ohm, (White Top)
    05 Temperature sensor, water 3-POL-2500-OHM 13621707366 most inner
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Only one on my 850. It has a yellow connector, located under driver side headlight assy and plugs into side of the air channel that cools the brakes.
    Nov 2014
    Stockholm, Sweden
    1992 BMW 850
    Thanks.
    What year is your e31? M70 or M73?
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    92 850. M70
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Here are pics of the two sensors. The yellow one is the same one BMSman was describing. So what's the other one?
    Nov 2014
    Stockholm, Sweden
    1992 BMW 850
    Was it just hanging there? Where? I also have a 92. It looks familiar but I can't remember where I have seen it.
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    See the answers in the post I made about the very same sensors a couple of days ago as to where they go: https://www.bimmerforums.com/forum/s...essure-sensors
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by BMSman View Post
    There are 2 air temp sensors - 1 in each brake cooling duct. The one on the drivers side (left) is similar to the ones in the rear of each intake runner on the M70. The other one on the passenger side (right) is actually a "button". Both are mounted to the underside of each respective duct.
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    It was properly seated on the underside of the passenger side duct but wires were cut. Not sure where it's supposed to connect to?
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Temp Sensor
    I am going to go look for mine tonight. Car has been running rough since the temperature dropped and this would I assume affect it if missing or damaged.
    I am missing my left brake duct, it was gone when I bought the car. Thanks for the Pictures
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Missing Sensor
    My Entire Duct is missing this picture was taken from the Driver Side Wheel Well. Car is a 1991 850. I found the sensor PN for the 94+ but could not find one for the 1991 on Real OEM, I did not see any buttons or the Yellow electrical Connector either. My right duct is intact, I am going on the assumption everything there is intact.
    Looking for the PN for the sensor
  1. oil temp sensor for drain plug
    By John (PA) in forum 1991 - 1999 (E36)
    Last Post: 05-30-2002, 04:49 PM
  2. adding coolant temp sensor
    By fourfa in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2002, 11:14 PM
  3. Temp sensor
    By TonySetliff in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-17-2002, 09:07 PM
  4. do 98-99's have an oil temp sensor factory installed?
    By RS in forum 1992 - 1999 M3 (E36)
    Last Post: 05-30-2001, 07:23 PM
  5. Need help finding Intake Air Temp. Sensor
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 04:52 AM
