Results 1 to 9 of 9
Thread: OBD I or OBD II?
    Oct 2008
    london
    840ci
    OBD I or OBD II?
    Hi all,
    Is there a way of checking if my 840 is OBD I or OBD II from the VIN?
    Cheers
    Mar 2017
    Milwaukee, WI
    1996 BMW 850C1 M73
    Model year 96 and newer in the us were required to be OBDII. But my 96, 10/95 build does not have the connector.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    None of them do, they all retained the 20-pin round connector in the engine compartment even though they are OBDII
    Mar 2006
    Harrisburg, PA, USA
    x5, 750i, 850Ci, 850CSi
    Quote Originally Posted by Higgilo View Post
    That's intersting, because my 9/95 build '96 850Ci has both the round connector under the hood and the typical OBD-II connector under the driver's side dash. Although it doesn't (and never did) have the coin holder in the driver's door.
    Mike Barrett
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    Mar 2017
    Milwaukee, WI
    1996 BMW 850C1 M73
    Quote Originally Posted by mbarrett635 View Post
    Mike Barrett
    Then mine must have been very neatly removed because I can find no evidence of it ever existing.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    OBD II cars ALL have the 16-pin flat connector, otherwise it couldn't be read by State emissions testing facilities - probably yours was removed as you suspect.
    '93 850Ci - Mineralweiss Metallic
    ALPINA B7 -Alpinweiss III
    BMWCCA E31 Chapter President
    Nottingham, UK
    E31, E36/7, E61
    Only 20 pin on my 7/97, UK car.
    Dec 2010
    Newbury Park, CA
    1995 BMW 850CI
    I believe all 840's 96 and newer and all 850's 95 and newer have the flat OBD-II connector (at least in the US, not sure about other countries). I've read where the clips to the connector can break and the owner zip-tied it up so maybe you'd have to look up higher behind the dash.
    EricinConejo
    1995 850CI, 1959 Chev Impala, 1965 Cessna 172, 1986 Mustang GT, 2001 VW Beetle, 2002 Mustang GT, 2005 Dodge Durango Hemi, 2006 Acura MDX
    Feb 2016
    Norwalk, CT
    1995 840Ci, 2013 X5
    I seem to remember this being discussed before. IIRC, US spec cars had the standard OBDII port 1996 and newer, while it did not have to be fitted to non-US cars like yours. It can be confusing because US spec OBDII were produced at the same time as OBDI cars. I don't recall any M62-powered 840's being OBD1. Certainly no M60's are OBDII.
    To answer the original question, perhaps try realoem.com. Pull up your car by VIN. Look at something that only an OBDII car would have like 4 lambda sensors. If your car requires 4, it is OBDII. If 2, it is OBDI. I know realoem isn't perfect, but it might give you the right answer. Or check the 8-series registry: http://www.8coupe.com/Production/Chassis.aspx. You could also call your BMW dealer for a more reliable answer.
    Brett
  1. Coil packs $10 each, not sure if they are obd-1 or obd-II
    By themadhatter in forum New York / New Jersey / Connecticut
    Last Post: 01-10-2011, 09:19 AM
  2. Coil packs $10 each, not sure if they are obd-1 or obd-II
    By themadhatter in forum Engines, Performance Parts & Software
    Last Post: 11-24-2009, 02:28 AM
  3. OBD-II w/m50 manifold, which BBTB? OBD-I or OBD-II
    By Captain in forum 1991 - 1999 (E36)
    Last Post: 03-18-2005, 01:37 PM
  4. OBD I or OBD II on 95 750iL
    By lucal in forum 1995 - 2001 (E38)
    Last Post: 03-07-2004, 04:06 PM
  5. Possibly buying a used E36 M3 (OBD I or OBD II?)
    By Deutscher Konnt in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2003, 02:04 AM
