Results 1 to 17 of 17
Thread: Idles fine, overheats when driving
    Dec 2016
    Sacramento
    2002 BMW 325i
    I have a 2002 325i that's having cooling system issues. I have replaced the thermostat, water pump, expansion tank and neck, all hoses, radiator, put new o-rings on temp sensor. And probably more. It idles fine for 30+ minutes but as soon as I drive it more than about 2 miles it starts to heat up and build pressure. I've tried everything that I can think of. No white smoke and no water in the oil. So I think my head gasket is fine? Any ideas?
    Dec 2013
    Chicagoland area
    EXOTICS
    Follow proper bleeding procedures.
    If still no improvement,
    have a cylinder leakdown test performed.
    Dec 2016
    Sacramento
    2002 BMW 325i
    Thank you. Do u have a proper bleeding procedure that you recommend? I've tried several and not 100% sure if any of them is correct or efficient.
    Dec 2013
    Chicagoland area
    EXOTICS
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What brands of parts did you install? Aftetmarket cooling system parts are VERBOTEN as the cooling system is the E46’s Achilles heel.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by Dcbean55 View Post
    Please do not be offended by my suggesting this, but are you sure you have enough coolant in the system? I had a Lexus doing this and it turned out I needed to add coolant. Thought there was enough, but there wasn't.
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Dec 2016
    Sacramento
    2002 BMW 325i
    I checked coolant level and it's good. I actually was convinced it was a cracked head or blown head gasket but I did a compression test and used a block tester and everything came out normal. No combustion gases in radiator and no leaks. I am at a loss at this point. I just can't figure it out. All replaced parts are new but purchased mostly at O'Reilly's auto parts. They weren't cheap by any means but maybe I should question the quality as MarcoZandrini mentioned above. As of now, still idles for as long as 30 minutes without incident until I drive less than 2 miles and pressure builds up very quickly and I have to stop before it blows something to relieve that pressure. Thanks for all the responses. I will update if I ever figure this out. For now, I'm in a rental just to go to and from work. Thanks again....
    Dec 2013
    Chicagoland area
    EXOTICS
    That sounds like a headgasket leak.
    Top off coolant so you can easily observe bubbles,
    then perform a cylinder leakdown test to confirm leak.
    Dec 2016
    Sacramento
    2002 BMW 325i
    I'm bleeding it again right now and it seems tons of air is coming out. In the past I didn't have heater on hot with fan on high. But I am still only getting cold air from heater. It just now went up to red on temp Gage and I added water , it immediately went back down to normal and heater got Luke warm.
    Dec 2016
    Sacramento
    2002 BMW 325i
    Still never got more than Luke warm heater. Doing another block test while it's hot.
    Dec 2013
    Chicagoland area
    EXOTICS
    Due to the compressed air/gasses being infused into coolant passages.
    LEAKDOWN TEST
    Dec 2013
    Chicagoland area
    EXOTICS
    Dec 2016
    Sacramento
    2002 BMW 325i
    I agree with you on the leakdown test. I'm gonna have to bring it down to a shop or buy a leakdown regulator tool. Either way I think that's the answer at this point. Thanks so much for your input.
    Dec 2016
    Sacramento
    2002 BMW 325i
    Block test still showed good even after I tested when hot. Go figure.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Installing aftermarket cooling system parts in an E46 is verboten. Why? They’ll fail and you’ll end up either redoing the work with quality parts OR you’ll end up with an overheated engine.
    Dec 2016
    Sacramento
    2002 BMW 325i
    Thank you MarcoZandrini....I'm investigating that now.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    Staying cool at idle and heating up while driving is a classic sign of a clogged radiator
  1. Idles fine, stalls when RPM's drop too fast
    By str99 in forum 1991 - 1999 (E36)
    Last Post: 01-16-2016, 08:09 PM
  2. 2001 325ci is OK when idle, but overheats when run.
    By Vals in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-01-2015, 11:37 AM
  3. Replies: 7
    Last Post: 01-24-2014, 11:32 AM
  4. Stereo acting up: fine when motionless, spazzes when driving
    By CaliAgents in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-20-2006, 01:39 AM
  5. idle fine(1000rpm)when cold.engine warms up idle lowers(500)
    By takem2church in forum 1991 - 1999 (E36)
    Last Post: 12-15-2005, 09:41 AM
