Results 1 to 8 of 8
Thread: Coolant reservoir cap stuck
    Mar 2011
    Hawaii
    635csi, 330ci
    Trying to get my 6 back in shape, along with dealing with power steering noise, had the coolant warning light come on. Went to top off the coolant but the coolant cap is stuck. I can turn it the quarter turn to release the tabs, but it won't come off. Searched but didn't find any threads for an e24. I'm hesitant to force or pry it off, I don't want to damage the reservoir. Has anyone run into this issue that can offfer some advice on what to do, or what not to do? I didn't want to force the cap, unplugged the coolant level sensor and unscrewed the plastic nut it's in and filled the coolant through that hole. Coolant light on the control panel went off but came back on a few minutes later, maybe the level sensor is no good, maybe the connector.
    The car is a '89 635, 33,xxx miles, has been sitting for most of its life for years at a time. Honestly the last time the cap was opened was likely over a decade ago, maybe even 15 years. I got it from the previous owner about 8 years or so ago, it's mostly sat under my ownership as well. Very likely with the exception of the oil filter everything under the hood is factory original.
    Appreciate any tips or experience anyone can throw my way.
    Savannah GA
    '73 ///M2, '85 ///M635
    Well, I'd spray some WD-40 or similar under it.
    Good luck,
    Ray
    Dec 2013
    Chicagoland area
    EXOTICS
    Delicately, with a rubber mallet.
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Push down on cap while twisting. I've had my 6 for 30 years and the cap has always been a tough one,
    even with a new overflow and new cap.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Quote Originally Posted by 1986series6 View Post
    +1 Had this same issue yesterday and it took a lot of downward pressure to get the cap to turn all of the way
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Mar 2011
    Hawaii
    635csi, 330ci
    Quote Originally Posted by MIKYZZ4 View Post
    Quote Originally Posted by rlkrlk View Post
    Good luck,
    Ray
    Quote Originally Posted by Bert Poliakoff View Post
    Ill give it that technique a try. Thanks guys!
    Dec 2022
    Nebraska
    '16 340i xdrive
    MIKYZZ4, I want to thank you for this simple reply which solved my problem! I'm female, 100 pounds and the cap was way beyond my strength level. Gentle rubber mallet taps worked like a charm! Thank you!
    Dec 2013
    Chicagoland area
    EXOTICS
    Glad i was able to solve this so easily.
  1. BMW E36 M3 Overflow Coolant Tank Reservoir Cap Temp Sensor 92-99 323 325 328 - SOLD
    By rs4eva in forum Engines, Performance Parts & Software
    Last Post: 06-18-2015, 11:00 AM
  2. coolant reservoir cap leaking
    By manny380sl in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 02-06-2013, 05:12 PM
  3. urgent: WTB coolant reservoir cap e30
    By durtythirty in forum Georgia sponsored by Harrison Motorsports
    Last Post: 01-16-2013, 06:41 PM
  4. Replies: 14
    Last Post: 12-10-2011, 12:24 PM
  5. ***Noticing OIL in COOLANT Reservoir!! ***
    By mini///m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-18-2002, 02:35 PM
