Results 1 to 6 of 6
Thread: is <1MM of play on water pump normal?
    Edgewater, NJ
    POS E36
    Commuting home my tensioner pulley grenaded and took out both belts.
    While inspecting for damage I noticed the water pump has <1MM of play in/out, is this normal?
    it is a metal Graf water pump with less than 10K miles on it
    if not normal i'd rather not remove it for faster repair
    thanks!
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Thrust Paly of a millimeter? No. The water pump should not have any play in any direction.
    Jun 2010
    NY
    1997 328i
    I would say it's fine.
    I hope you were able to pull over and turn the engine off super quick!
    Edgewater, NJ
    POS E36
    Quote Originally Posted by Eric93se View Post
    Yep pulled over within 100 ft of losing power steering and battery light coming on.
    Edgewater, NJ
    POS E36
    You were right
    Bought and installed a new Graf water pump and it also had same 1mm play.
    Oh well can’t go wrong replacing cooling on these cars ahead of schedule.
    Jun 2010
    NY
    1997 328i
    lol, nope.
  1. OEM Brand of Sensor on water pump
    By RSharma in forum 1995 - 2001 (E38)
    Last Post: 11-28-2016, 12:57 AM
  2. how difficult is it to drill out the water pump bolts on the m50 engine?
    By inkacola in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-10-2013, 05:19 PM
  3. Replies: 18
    Last Post: 11-18-2010, 12:07 AM
  4. Replies: 12
    Last Post: 08-25-2004, 05:25 PM
  5. Replies: 7
    Last Post: 06-08-2004, 02:37 PM
