Results 1 to 11 of 11
Thread: bmw e46 fuel trims
    Feb 2018
    georgia
    bmw e46 2003 sedan
    bmw e46 fuel trims
    i have very large fuel cunsomption with no eror codes
    Feb 2018
    georgia
    bmw e46 2003 sedan
    Feb 2018
    georgia
    bmw e46 2003 sedan
    [IMG][/IMG]
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Look for vacuum leaks.
    Feb 2018
    georgia
    bmw e46 2003 sedan
    i cheked the vacuum with smoke. there is no leaks
    Jan 2016
    Ca
    2001 525it
    We found a vacuum leak athe booster for the brakes and the smoke came out from under the dash when we did the smoke test
    May 2010
    Honolulu, Hawaii
    E30, E9, E36, E32
    Leak in fuel system? Smell of gas when parked, wet stain on the ground?
    Someone siphoning gas from the car when you're not around? Watch the gage when you shut down and when you next start.
    Smell of gas at idle? Walk slowly around the car sniffing for it, down low too, not in a windy place.
    Leaking fuel line when under pressure? Look under the hood and under the car at idle, check pressure at fuel rail after shutoff.
    Stuck pressure valve, check fuel pressure at idle and at higher rpm.
    And the number one thing: what have you done to the car lately that has had anything to do with the fuel system? Mechanic's rule, y'know...
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Feb 2018
    georgia
    bmw e46 2003 sedan
    fuel does not go out nowhere... i cleaned injeqtors, changed fuel filter, air filter. the fuel pressure is abaut 3.5 bar (50psi)
    Vermont
    97 328i Vert, 98 M3 Vert
    You probably have a vacuum leak. Smoke tests aren’t always accurate. They perform that test under very low pressure. I’ve had situations where there was a split in the intake boot and it didn’t show any smoke but the high vacuum when the car was running was enough to cause thT split to open and allow lots of air to get in. Most likely culprit is the inner intake boot
    Dec 2013
    Chicagoland area
    EXOTICS
    Bank 1 only, I assume?
    That should narrow down the leak locations to be bank specific.
    Feb 2018
    georgia
    bmw e46 2003 sedan
    in smoke test presuure was 3 bar and the intake was holding the pressure
  1. bmw e46 fuel pump for sale brand new central NJ
    By mvancE30 in forum New York / New Jersey / Connecticut
    Last Post: 02-01-2016, 12:36 PM
  2. Replies: 0
    Last Post: 06-12-2015, 11:20 PM
  3. wax on bmw e46 exterior trim.
    By bmwe46330xi in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 04-20-2011, 10:38 AM
  4. LF: Bmw E46 Interior Trim Kit Coupe and Sedan
    By euroguy in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 03-26-2011, 10:06 PM
  5. E46 BMW E46 Radio Trim Panel Kit Scosche 3-Series 1999-2006
    By ttgxc in forum Car Audio & Electronics
    Last Post: 01-01-2011, 05:21 PM
