Results 1 to 17 of 17
Thread: How much are lap times affected by a heavier wheel?
    New England
    E36 M, E32 740i/6, 997 S
    I am currently running a square set of DSIIs which are about 23 lbs each if I remember correctly. I conceptually understand how a lighter wheel affects acceleration, braking, and the inertia of the suspension components under compression and rebound, but I am wondering how much of a quantitative difference it makes on performance. How much of an improvement could I expect to see in my times if I were to run a set of rims like ARC-8s in the ~17 lb range?
    California BAY AREA
    e30 M3, 335d
    You cannot really quantify how much time can be shaved each lap with a lighter wheel. This weight loss is unsprung mass, which will improve how the car handles, brakes and accelerates. This weight savings could be good for 0.05 seconds or 1.05 seconds, it depends on many other factors. Static mass vs. rotational mass is calculated around a 1:5 ratio.
    Meaning that for every 1 lb at a stand-still, that is about 5lbs when rotating. If you are saving about 6 static lbs per corner, that means in total, you're saving 24 static lbs. Rotational mass of this would be 24 static pounds x 5 (1:5 ratio) = ~120 rotational pounds.
    Total weight saved while in motion would be around 120lbs! So imagine you are basically saving the total weight of a smaller adult woman just by moving to a lighter weight wheel.
    Is this something you would notice? It is hard to quantify exactly how many seconds a lap it would be worth, but the weight savings do improve the entire driving experience as a whole, so there is going to be significant gains in performance.
    I hope this was helpful!
    - Max
    Sep 2010
    mid-atlantic
    70's p-cars
    I've done almost exactly what you're contemplating - switched a set of DSI for a set of ARC-8 on the same track on the same day with the same tires (Nitto NT01). I actually weighed the wheel and tire combinations and the DSI with the Nittos was pretty heavy at 45 lbs/wheel and the arc-8 was 38lbs - so there is a significant difference. Also keep in mind that the DSI is a 7.5" wheel and the arc-8 is 8.5. So lighter AND wider. Kind of a knife to a gun fight.
    I'm a pretty experienced driver and drive very consistent lap times - usually within a couple of tenths once I settle in for the weekend (half dozen laps on a new track, less on a track I've been to before). What I found is on a 1:30 ish track like summit main or NJMP I see about a 2 second a lap difference plus I feel the car is more responsive and easier to manage with the lighter weight wheels. Lime Rock would be less, Watkins glen, more, if only because those tracks are shorter or longer. That being said, any difference you might experience would depend on how much you could take advantage of the handling differences the lighter wheels might offer.
    In competition, a couple seconds a lap is a lifetime. If you're driving DEs it will be a noticeable difference but buying a set of arc-8s just for fun will set you back $1k. (I bought a second set of arc-8's to replace the DSI's. Ha!)
    ithaca Ny
    95m3/97m345/powerstroke
    Not sure how it happened here but....
    the top screen is on a 8.5 apex with a 245/40/17 r6
    the bottom is on 8.5 ds2 square with 245/40/17 re71r
    nothing changed with the car
    result is the same exact lap time. It really baffled me hence why the video was made.
    https://youtu.be/Q8xQ83H_mhw
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by Pat533i View Post
    Really different weather? Just muscle memory on the slower tires? It did look like there was much less "mid-corner adjustment" on the R6's vs. the RE-71R's. So maybe all the superior grip of the R6's just wasn't been utilized.
    It wouldn't be the first time I've seen it on people with lots of laps on a given car/setup. They bolt on stickier tires or a bigger wing etc. and turn the exact same lap times. Then there usually needs to be some coaxing to get them to utilize that extra grip where it's available.
    ithaca Ny
    Weather was about the same, r6’s only had one heat cycle. I can do 2:08s on r7s so I don’t think it was driver mod. Only thing I can think of is the taller diameter of the r6’s (taller gearing).
    Really need to to put the same tires on a heavy set of rims and then a light set. That would be the only way to know for sure. I should know more this season now that I’m going to heavy 18’s. Setup will be about 5 pounds heavier than the ds2’s. Hoping it won’t slow the car down too much.
    May 2005
    NYC
    05 M3 ZCP
    Driver error. Unable to capitalize on reduced unsprung weight.
    -@mannschaftschnell
    Vancouver, BC Ca
    1993 325is
    How old were the R6s and how old were the RE71Rs? It is entirely possible that old heat cycled out Hoosiers would be significantly slower than new fresh RE71Rs.
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    Dec 2013
    Parker, Colorado
    1996 BMW M3 Coupe
    Grassroots Motorsports magazine did this test, as well. I think the article was in a magazine last year??? Maybe the year before? I tried a quick google search and could not find the article on line, but maybe deeper digging will provide a copy.
    1996 BMW M3
    aka 'The Pirate Ship'
    NASA Rocky Mountain GTS Director
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    No way 7lbs per wheel/tire is worth 2s on a 1:30 lap even with the 1" width advantage. 2s is huge. People in my class have added 150lbs of ballast to cars with less than a second difference on a 2:20ish lap.
    If your DSIIs are 8.5" all around, i'd run 'em and put the money toward faster rubber. 17x9" ARC-8s are heavy anyway, but they are pretty tough.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by TXBDan View Post
    Agreed. Hoping to get 2sec from 28 lbs (total) of rotating mass is unrealistic.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Wut?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Nov 2005
    MA
    Quote Originally Posted by ScotcH View Post
    Wut?
    I just checked and see they're 17.8lbs in a 17x9 et42. That is pretty good, for some reason i thought they were 19lbs. I have ARC-8s and K1s and the K1s feel to weigh significantly less. Granted they're 1/2" less wide but the different in lugging around is real. I guess its just the tires that i have on them.
    Los Angeles
    M3, 911, NSX, DC5, AE86
    Another factor to keep in mind is wheel rigidity. Performance gained in weight can be lost in the flex. There was a Japanese outlet that tested RPF1's (lighter) vs Fn01r-c's (heavier), and the heavier wheel was faster. They determined it was due to wheel flex and the effect that had on the tire. Ideally you want lightweight and strong. My preference is one piece forged wheels, and Rays are what I typically use.
    Apr 2002
    Broomfield, Colorado
    Almost none. People like to talk about unsprung weight, rotational mass, etc - and certainly a lighter wheel is better than a heavier one.
    But in practice, if you swapped the same tires onto a 1lb lighter wheel, there's more variance in driving than in the weight difference.
    In my experience, anyway. Maybe you will be a MEEELION miles faster than everyone and go to ludicrous speed right in front of us.
    (Save your money.)
    (Aslo, a fast car is an awful lot of small things that add up to a big difference. Lighter wheels are just one of the small things.)
    Another thing to think about - even a lap around a skidpad would be absolutely no faster with lighter wheels. Nothing relative has changed. So, your cornering speeds won't be any different.
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by CoMZ302 View Post
    Except that on a minuscle (almost lost in the noise) scale, the lighter wheel will have an easier time following the bumps/undulations in the road surface potentially leading to higher cornering speeds!
  1. Replies: 4
    Last Post: 03-31-2007, 06:24 PM
  2. 95 OEM LTW rims - how much are they worth?
    By dmw in forum BMW Parts For Sale
    Last Post: 03-26-2002, 10:30 PM
  3. How much are Koni front strut carts?
    By sedate in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2002, 01:44 AM
  4. How much are the Mozart exhausts?
    By Sacramento M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-18-2001, 12:46 AM
  5. How much are rear brake pads installed?
    By Russell328is in forum 1991 - 1999 (E36)
    Last Post: 06-29-2001, 05:36 PM
