Up for sale is my 1987 e28 with an LS1 swap with working AC and heat.
The list of work done/parts involved is not all inclusive as I will not remember every nut and bolt used to complete the build.
The pictures show a dent on driver side fender, however that has been fixed and a couple pictures added to album showing current state.
Used Parts:
-LS1 with around 80K miles. Engine was resealed and a new water pump was installed
-Rebuilt T56 Transmission
-LS6 intake manifold
-Resealed 4.10 LSD
-Euro Bumpers
-Euro Headlights
-Euro Turn Signals
New Parts:
-GTO Oil Pan
-Diamond Stage II Clutch
-Pro 5.0 Short Shifter
-Aeromotive Adjustable Fuel pressure regulator
-New high pressure fuel pump
-Chromoly pushrods
-CSF Radiator
-16'' Spal fan
-Water Pump
-AC Compressor
-AC Lines, AC Condenser and Drier
-Heater Blower Motor
-Condenser Fan
-Spark Plugs and Wires
-Porsche 944 Brake Booster
-e32 brake Master Cylinder
-e34 M5 Brakes all around: New calipers, Rotors and Pads
-Custom one piece driveshaft
-Federal RSRR tires in 235/45/17 (Less than 500 miles on them)
-New euro bumpers rubber trim.
-VDO Oil Pressure gauge
-VDO Temperature gauge
-Innovate Motorsport Wideband AFR gauge
-Custom Headers
-Engine and transmission mounts
-Tie Rods
-Upper and lower control arms
-Moosehead Engineering Control Arm Bushings
-Idler arm
-Steering Center link
-Sway bar links Front and Rear
-Rear Pitman Arms
-MAP Sensor
-IAT Sensor
-AC and Drive Belts
-Expansion Tank
-QTP electric Exhaust Cut out
-Custom 3'' exhaust,with mid section muffler, high flow cat, and rear magnaflow muffler.
-Euro Bumper brackets
-Fortune Auto Coilovers still in box, willing to install, corner balance and align the car if asking price is met.
Dyno tuned at New Era Performance LLC in Agoura hills, it made 303hp and 330ft/lb TQ at the wheels.
Asking price is $18,950 Please consider what goes into a proper swap like this before questioning my asking price.
I can be reached at 818-703-2097 Call or text
Below is a link to google album of the car.
https://photos.app.*******/AAJ107CDzz1SCzmh1
Moderate thread necro, but was there a build thread for this car?
