Results 1 to 7 of 7
Thread: A little off topic and somewhat related
    Orlando, FL USA
    When replacing the valve cover gaskets on the M62 V8 motors, I would like to know how much sealant (ex: reinzosil ) is used on the surfaces prior to joining the valve covers to the heads. Is it a small dab all around the surface and then thin it out with your finger or maybe just where the corners are only?
    Looking for suggestions and rule of thumb practice.
    Thanks.
    Del Mar, CA
    91 850i, 01 740i, 06 760
    Place a small amount at corners and where the timing cover casings join.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by ChrisFuture8 View Post
    Thanks.
    I put a small film all around.
    Orlando, FL USA
    Thanks Dragon850 and BMSman!
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Doing this again - I would replace all the rubber grommets around each nut. I would also make sure the mating surface is spotless. Lastly, I agree with Dragon on sealant all around.
    Orlando, FL USA
    Quote Originally Posted by toomanyparts View Post
    Good call, Toomanyparts. Luckily, I did order the full set of rubber grommets as listed on realoem when I ordered the set of valve cover gaskets.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Never cover the whole surface. You just put a small dab and smear it with your thumb at the crease where the timing cover meets the head. Smaller than a dime. And then lay a thin coating on the half moons of the gasket itself. That’s it.
  1. A little off topic...but BMW related
    By glashaus in forum 1975 - 1983 (E21)
    Last Post: 05-04-2015, 12:25 AM
  2. A little off topic
    By MEnace in forum New England - US
    Last Post: 05-21-2009, 09:27 PM
  3. little off topic but courious
    By Monk183 in forum 1975 - 1983 (E21)
    Last Post: 07-17-2005, 07:22 PM
  4. A little off topic but still racing...caravan?!?
    By RRdawho? in forum Kill Stories
    Last Post: 06-17-2002, 09:25 AM
