So I tried to be productive this evening and was going to remove all of my fuel injectors to change the orings and clean and this happened.
Then...I compounded the issue by removing the tube from the fuel rail to get the plastic piece out...which resulted in a crumbling fuel delivery hose.
I realize that I have to replace the injector with another one.
Is there a way I can use a regular fuel hose and cut it to fit instead of paying 25 damn dollars per hose.
At this point i am afraid to take any of them off as the other injectors may meed the same fate.
Thoughts
Don't touch the other injectors, they will crumble.
Ebay sells replacements for the M73N, those are the only ones that work.
Facing a couple of injector fault codes myself. Ill be extra careful on those 20 year old plastic bits. (1998 750il)
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
THAT is awesome to know.
I've had a couple 01' 750's - glad to be out of the EKAT business as well.
You may want to check out this thread on the Gen III injectors on the M73. It is Ms bimmerlv story.
https://www.bimmerforums.com/forum/s...erlv+injectors
1997 740iL; 5/96 build. Purchased 12/04. Off the road build project 2013 - 2021. back on road 3/2021. Became daily driver (only vehicle) 6/12/2021. Still not completed. Stay tuned as the adventure continues.
Maybe you can plug the hoses and just use the Gen 3s, even on the N.
I'm in the process of converting mine to the prefacelift injectors. Much more solid injectors almost no plastic what so ever.
Sent from my VS995 using Tapatalk
By using prefacelift manifold, injectors, and now i just found out the fuel rail wont mount on prefacelift maniold. The mounting bolt for fuel rail narrower than facelift fuel rail. I have to hollow out the fuel pressure regulator on the prefacelift fuel rail cuz the facelifted already have a regulator under the car by the fuel filter.
So the best bet is to use all prefacelift fuel fuel rail, injectors, and intake manifold. Prefacelift and facelift parts are not all that compatible with each other believe it or not, very minor diffeneces but enough to say they are not quite interchangle.
So buy a 98 and swap the fenders and lights. ;-)
Seriously - good information for those fighting that fight. V12's can be a pain, but the payoff and accomplishment of taming it is pretty nice....as Im currently
doing.
This is the EXACT reason my intake gaskets havent been touched yet... Sucks to see, but glad to know my paranoia is justified. Keeping tabs on this thread though to see how it all pans out for everyone.
Current:
E38 2001 750iL - Current DD.
E36 1995 M3 Coupe - Ls1/t56 - FIXED...now with a Ford 8.8 IRS Rearend
E36 1998 323is Coupe - Back-up DD.
R53: 2005 MCS W/ GP and JCW bits. - Wifes Project Car
Past:
E36 1999 Dinan M3 Coupe AW/Sand Beige - In BMW Heaven.
Probably quite late response, but here you have a few choices:
Buy a new fuel injector, I'd say would cost around a hundred bucks;
Look around on the internet for used one (I was lucky and bought few while ago);
Fix broken bits using high quality compound glue;
My insight on injector tubes, which are at ~10 euros each (in Europe) - use regular fuel hose, cut in appropriate bits, then bent and fit on rail and injector. Do it carefully to avoid breaking other injector tubes.
In regards to O-rings on both injector ends, there you have a choice to buy genuine ones either buy same diameter, but cheap alternatives
Speaking from my own experience, I'd go for genuine O-rings. I have replaced work genuine O-rings with cheap alternatives and after a while when removed injectors to do other stuff I found that they were deformed,too soft and did not do the job like originals.
I bought a new fuel injector. I spent the money on an OEM hose to connect it to the fuel rail, bought original Orings for the top and bottom of each. The last thing I need is for something not to seal the correct way...start spraying fuel all over the place and me driving down the highway at 90mph with my engine on fire.
However...It looks like I am going to be putting sealer on my intake manifold gaskets. Max does not have his kit in stock. I was thinking about buying these...which would put the price at 100 each....but something doesnt feel right with this guy...seems kinda sketch.
Its through amazon...no one answers the phone...I tried to email to clarify the quantity and price and got no response.
'01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
'99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
'84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
No...I tried calling a number of times during the week...and it is always answered by via IP office and they are not available. I call between 11 and 12 my time. which is 8-9 their time. They also did not respond to email
Don't know what's posted on Amazon, but here is their main phone number: (415) 863-9000 maybe they can give you the answers you desire. No affiliation myself, but finding it odd the problem you are having getting in touch with them. Hopefully this will help.
