Results 1 to 11 of 11
Thread: Which brake bias proportioning valve?
    Aug 2012
    Central, MD
    1995 M3
    Which brake bias proportioning valve? In order of increasing cost; Wilwood, Tilton, AP Racing.
    The AP Racing is 2-3x the cost of the Wilwood, but it also advertises as having a wider range of pressure adjustment, I think.
    For an E36 M3.
    Mar 2013
    Upstate NY
    M3
    Hmmm, yeah has someone done this?
    Aug 2012
    Central, MD
    1995 M3
    FYI, I purchased a Wilwood. Seemed to have the same adjustment range as the much more expensive AP Racing piece. I'll report back when I install.
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    I have the Wilwood click type in my car, works fine.
    I rarely touch it.
    When I want a little less rear,,, back it off a click or two,,, all good.
    I dont think you need a huge range of adjustment on these things unless your brake system is flawed at the genetic level.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Apr 2002
    Broomfield, Colorado
    I use the lever type - it's fast and easy to be positive about what you've done in the chaos of the race.
    https://www.pegasusautoracing.com/pr...p?Product=3528
    Fair warning, I've removed the ABS due to class rules. I still use the stock (328) master, however.
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    I like the screw type (put a white or yellow mark on the adjuster, otherwise you can't tell where it is). I typically moved it about half a turn either way from "feels good" depending on conditions and it seemed to make a small but noticeable difference in bias. The lever type seemed like it'd be hard to really dial in and get a repeatable setting.
    FWIW, I can't imagine needing more adjustment range than the Wilwood valve gives, I think it can move the knee point up to like 1500 psi, which is typically around peak pressures you find in a braking system. I ran it about 40% the way down its adjustment range FWIW.
    Jan 2003
    Detroit area
    09 128i, 03 525iT, 95 M3
    Quick question rather than starting a new thread. If ABS is not disabled can the adjuster valve just be added in the line to the rear brakes, or does it need to be plumbed in between master cylinder and the ABS module? 95 M3 w/ a 3 channel system. Thanks.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by JPJ View Post
    After reading how the Teves MKIV ABS system works, I'm convinced the ABS is purely pass through until one of the wheel sensors sends a signal that a tire is starting to slip. So, I'm mounting my valve in the rear brake line (mine is 95 3-channel also).
    Def's Avatar
    Aug 2002
    SW22, Volt
    I'd have my doubts on a brake proportioning valve/regulator working well when hammered with ABS pressure pulsations. I would have put it before the ABS pump.
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I have the SSBC one, no complaints
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by Def View Post
    Fair point. I also have questions about how it would work located prior to ABS pump. In the E36 ABS, an inlet solenoid blocks the inlet side of the pump whenever ABS is activated, so the proportioning valve would be temporarily removed from the circuit. I don't see a problem with this, until the ABS turns back off?? Not sure.
    I think the only way to know for sure is to try both. So, I'll pick one, and if it works, be happy.
    Quote Originally Posted by Novablue454 View Post
    With ABS? If yes, did you install prior or after ABS pump?
  1. Installation of an adjustable brake bias proportioning valve. Anyone done it?
    By TheOtherEric in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-20-2010, 08:34 PM
  2. Brake Proportioning valve
    By greggearhead in forum 1975 - 1983 (E21)
    Last Post: 08-02-2006, 08:30 PM
  3. Brake bias -- brake proportioning valve use ?
    By FierySphere in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-18-2005, 07:17 PM
  4. brake-proportioning valve?
    By BJO in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-14-2004, 02:05 PM
  5. Brake Bias Valve
    By 500kE30 in forum 1983 - 1991 (E30)
    Last Post: 05-09-2004, 11:02 AM
