Results 1 to 25 of 27
Thread: E39 M5 ABS Bumpers available Now
    Feb 2001
    East Bay, CA
    M5, E61
    after a long absence, the E39 PP are in stock and so are the ABS.
    https://www.umnitza.com/e39-5-series...per-front.html
    Get them while they are "hot".
    Give us a call 877 486 6489
    Also, have PP bumpers with washer cut outs if you have a cold climate car...
    https://www.bimmerforums.com/forum/s...vailable-QTY-1
    May 2017
    Houston
    03' 540i, 05' 545i
    I've been reading into the replacement process in depth. Can you, as a 1st party, tell me what the differences between your product and the OEM ABS bumpers are?
    I am seriously considering pulling the trigger on a front and rear set soon. Thanks
    Feb 2001
    East Bay, CA
    M5, E61
    There is not a huge difference other than the lack of logos. ABS bumpers even have the same mold markings on their back just like the OE bumpers.
    for PP, yes, we've had some issues, but ABS, pretty rock solid. As good as OEM for usually 1/2-2/3rd the price.
    Roswell, GA 30075
    2003 540i Sport - 6 Spd.
    What about the fitment issues? The bumper cover doesn't typically align perfectly with the fender line. Can you provide commentary about that?
    '03 540i-6
    153k mi; bought April ‘07 w/38k mi
    Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
    Feb 2001
    East Bay, CA
    M5, E61
    The PP doesn't align well, but the ABS does. it's a different type of bumper so has better fit overall (as well as feeling more substantial when compared side by side).
    Roswell, GA 30075
    Quote Originally Posted by umnitza View Post
    Does it align as well as the BMW OEM part? And what are the pros and cons of the ABS product? For example, is it more or less prone to cracking, etc., than the OEMs?
    '03 540i-6
    Feb 2001
    East Bay, CA
    M5, E61
    ABS is more rigid, paints better, generally a better fit.
    PP is more soft and in colder climates doesn't crack as easily.
    OE are pretty prone to cracking, no different than the ABS in our experience. PP is not as common but it's usually short.
    It matches with the fender liner on the front but we recommend if you are doing this to be as OE as possible you should get the M5 fender liner and "pork chops" otherwise it will still work.
    Feb 2001
    East Bay, CA
    M5, E61
    Jul 2010
    baldwin, ny
    2003 540MSPORT 6 #861
    how much extra is the painting service?
    2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
    Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
    36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
    EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4
    cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Quote Originally Posted by evomel View Post
    $249 I think. With PPG paint that is what my painter uses.
    Jul 2010
    baldwin, ny
    Quote Originally Posted by jp5Touring View Post
    thats not bad $500 for a replacement bumper
    Feb 2001
    East Bay, CA
    M5, E61
    $250 for most paints - like Jet Black, Alpine White, TiSilver.
    For some more custom paints we'll usually ask a little more...by custom we mean Seafoam Green or similar non-typical ons.
    Jul 2010
    baldwin, ny
    how about sapphire black?
    Feb 2001
    East Bay, CA
    M5, E61
    BSM - that shouldn't be a problem, same price as the others. It's a more common color, though very uncommon for E39s, it's very common on E60s and E9X and we ship a bunch of those pre-painted.
    Sep 2004
    NorCal-Belmont
    '01 530i s/p/5spd
    Anybody purchase an ABS bumper with paint? How is the paint match? Quality?
    Feb 2001
    East Bay, CA
    M5, E61
    We have 5 Ti-Silver going out today, got a pic only of the rear for now because the front is already packaged.rearbumper.jpg
    Can email you a full size, just email us @ umnitzaship@gmail.com - we can send you an 8MB blow up of this, you can zoom in as much as you want.
    Feb 2001
    East Bay, CA
    M5, E61
    Got a bit of a delay - painter was in the hospital, we're back up to full operation now.
    Oct 2017
    On a hill
    03 525i, 15 Mustang
    Ordered mine in Sterling Grey - didn't send anything to paint match because I live without fear.
    Match came out really well, I have no issues with it, although I am also not a concours judge, so other, pickier people may have a different perspective. There were a couple of small blemishes on the face of the bumper, but I didn't notice them until I was like 2-3 inches away and I'm pretty confident the first summer detail will most likely take care of them.
    Also, the rub strips were unpainted. I prefer the unpainted look, but if you want body color ones, probably should ask about that first.
    No pictures because first post, but imagine a grey touring with an M5 bumper and there you go.
    Feb 2001
    East Bay, CA
    M5, E61
    Thanks for the feedback! We have a few more in people's hands so hopefully soon we'll have some actual folks on here posting pics.
    Sterling Grey is one of the harder colors to match.
    Jul 2010
    baldwin, ny
    I'm just a little confused - I saw this on fb this is the PP - standard non-ABS is this the less expensive version or more expensive version?
    Feb 2001
    East Bay, CA
    M5, E61
    PP is less expensive and softer and more resilient to hits, ABS is better fitting and works with paint better.
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Just placed my order for a rear ABS M tech bumper last night in Black Sapphire Metallic, excited to replace my faded OEM non sport bumper. Need to find better aftermarket exhaust solution though.
    2003 530i M Sport [Black Sapphire Metallic & Sand Interior]
    IMG_1075 by Alex Wilson Photography, on Flickr
    Feb 2001
    East Bay, CA
    M5, E61
    got it! you got in on the one of the last few we have of the rears.
    good news, site was live last night, bad news, it's down right now for those interested, please wait 1 hour and you'll be able to order once again.
    WE found an error and it's a looped error so we have to fix it before it causes more issues.
    Jun 2017
    Chicago
    guess I'm lucky, will the body trim mouldings be painted body color or do I need to request that separately?
    Sent from my Pixel 3 XL using Tapatalk
    CT
    E28, E32, E39, E53, E90
    Here's my experience with the PP bumper. Fit quite well, very slight gap. If I did it again I would go with the ABS though.
    direct: https://youtu.be/jpwFpRzDmGk
  1. E39 FS: E39 M5 Front Bumper $350
    By killerkiko in forum Exterior Lighting & Body Parts
    Last Post: 02-25-2018, 12:13 PM
  2. ••ü•• umnitza.com E39 M5 ABS Bumpers available late January 2018
    By umnitza in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-22-2018, 02:19 PM
  3. E39 2 E39 M5 rear bumpers / 1 E39 M5 front bumper
    By paopao in forum Exterior Lighting & Body Parts
    Last Post: 07-21-2008, 10:00 PM
  4. E39 FS: E39 M5 Lower bumper mesh grille NEW
    By Manny G. in forum Exterior Lighting & Body Parts
    Last Post: 03-28-2008, 09:53 PM
  5. E39 FS:OEM E39 M5 Front bumper
    By bmwhumper in forum Exterior Lighting & Body Parts
    Last Post: 03-13-2007, 01:30 AM
