Results 1 to 3 of 3
Thread: Brake bias valves, how do they work?
    Aug 2012
    Central, MD
    1995 M3
    Question Brake bias valves, how do they work?
    I don't really understand how these work.
    Let me explain. Brakes work on pressure, not fluid flow. I get that there IS a very slight amount of fluid flow.
    How do these valves reduce pressure on the down side of the valve for more than a fraction of a second?
    I could see where they might reduce the rate at which braking pressure is applied.
    Do they really reduce braking bias for long applications of braking (e.g. at end of straight where brakes might be applied for a few seconds)?
    Am I missing something?
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    It's not a "valve" per say, it's actually a pressure regulator that has an outlet pressure gain set by the geometry of the internal components (i.e. the 57% pressure gain you get on the outlet vs. inlet above the knee point).
    This has some information on how it functions, and I'd assume it's a single stage regulator due to the size and application:
    https://en.wikipedia.org/wiki/Pressure_regulator
    At least that's my understanding of how they work without cutting one open, but it seems consistent with their operation. You're right in that it can't be something like a needle valve, as that only throttles pressure based on pressure drop vs. flow.
    Aug 2012
    Central, MD
    1995 M3
    BINGO!! This makes perfect sense now. Not a flow rate regulator but a pressure regulator (by regulating the volume).
    Thanks!!
    Quote Originally Posted by Def View Post
  1. Adjustable brake proportioning valves - how do they work?
    By TheJuggernaut in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-31-2014, 08:49 AM
  2. E36 side lights, how do they work?
    By kirbykirbykirby in forum 1991 - 1999 (E36)
    Last Post: 05-01-2008, 07:22 PM
  3. rear view mirrors: how do they work?
    By cS in forum Off-Topic
    Last Post: 06-11-2003, 03:36 PM
  4. Spring Rates: What are they and how do they work?
    By Ben Carufel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-28-2003, 11:10 AM
  5. CF Hood pins how do they work ?
    By nicot in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-11-2003, 05:05 AM
