Page 1 of 4 1234 LastLast
Results 1 to 25 of 96
Thread: Good Bye Yall
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Good Bye Yall
    Well last night I messed up. Was entirely my fault. Don't really feel like going into details.. but my pride and joy is done. Didn't even know how to change oil when I bought this car and built it into something special. Kinda devastated about it..
    Had a good time with you FI BMW guys. Was fun while it lasted.
    Sent from my SM-G900V using Tapatalk
    Louisville, KY
    turbo m3
    Wow!
    I'm glad you are okay. You will be back... It's in the blood now.
    Apr 2006
    Minnesota eh?
    86 325es
    Get another chassis and swap it all over. Glad your okay.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    That is a bummer. Like others have said, you could try to fix or swap to a better chassis.
    Manchester, N.H.
    96 332IS 6466 turbo
    Lose control ? Or drinking ? Or just an accident ?
    I have done all 3 i want to say.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    Feb 2012
    1995 BMW M3
    Lost control of the car.
    Feb 2012
    1995 BMW M3
    I haven't decided if I'm going to try and swap everything to another m3 or just part it out and move on.
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by rajicase View Post
    You ain't going nowhere.
    Just like Pringles...
    Were those REAL EURO headlamps?
    Bellingham, WA
    e30
    Ouch! Glad you are OK!!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Glad you're OK raj
    Swap it over and do it again...
    Most of that will go straight into an E30 chassis
    Sent from my G8141 using Tapatalk
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Ooof! Glad your OK. E30 would be very cool!
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Makes me sad
    Manchester, N.H.
    96 332IS 6466 turbo
    This example is a perfect reason why I feel 500-550 whp is much better for the street. Even tho it can be dangerous as well. My experience is that with shitty roads, 650-700+ is a handful and a 1/2.
    1996 332IS
    Built 3.2
    Feb 2012
    1995 BMW M3
    Yeah ~700whp, cold drag radials and roads, and a road I was not familiar with was a perfect storm. Totally my fault..
    Jun 2005
    New England
    At least you weren’t hurt.
    Feb 2012
    1995 BMW M3
    True, lost control at about 80mph. Could have been way worse. Back of my car hit around 50mph and then the front hit at less then 10mph.
    Mar 2013
    Upstate NY
    M3
    Dude don't call this quits....you can't be upset when you crash man it happens to a lot of people. Buy a new chassis and keep going. I've already crashed two e36s, and now Im on my third.
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Looks fixable
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
    Virginia
    97' m52 turbo
    Quote Originally Posted by NY98M3 View Post
    Looks fixable
    Full coverage?
    But is probably fixable.
    AL
    99' M3, 98' M3, 13' X5
    That sucks, but glad its just the car! PM or txt me if you decide to jump back in, there's usually something available locally.
    Mar 2012
    Renton, Wa
    98 m3
    Hopefully full coverage dude. Glad your safe.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Apr 2017
    Florida
    E36
    Thankful your ok
    Jul 2005
    PEI, Canada
    2001 330i
    I'm glad you are OK.
    Cars always need "work", this is just a different kind.
    A house
    '86 325e, '14 VW EPA
    This isn't the time to make any decisions. Put it away for a few weeks and after the emotions get less raw see how you feel. It sucks but as far as wrecks go, it's pretty minor. All the important bits can go into a new shell. Or even rebuild this one if it means a lot (that's what I'd do if I dorked up my E30, I'd have to pretty much burn it to the ground in a crumpled up ball to throw the whole car away). But if you're just not really interested in doing this anymore, or with this car, that's a different matter but it shouldn't be a decision you make while emotional.
    Jan 2018
    Arizona
    93 325is
    That sucks man I'm so sorry hope you don't give up bimmers
    Sent from my SM-G935V using Tapatalk
  1. Good-Bye M3 & HeLLo 911 Turbo
    By Yasir in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2004, 10:22 PM
  2. Good-bye Bilstein, Hello Koni!!
    By Ron17 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-04-2003, 06:21 PM
  3. Good bye Rx-7 looking for Mcoupe
    By mendizabal in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-28-2003, 01:50 AM
  4. Good Bye everyone
    By AlpWhitE46 in forum Off-Topic
    Last Post: 03-18-2003, 03:27 PM
  5. Replies: 42
    Last Post: 07-23-2002, 06:41 PM
