Results 1 to 20 of 20
Thread: Wheel and brake combo
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Just a preview. Full reveal this coming spring.
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Looks great! 345mm rotor?
    You can probably fit 360mm under the wheels.
    San Francisco, CA
    No, only 332mm rotors. Unfortunately, this is the biggest Brembo setup for the e31.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    European CSIs use 345mm rotors with the 4 piston Brembos. I believe that’s why he asked, Ive seen some people do that swap.
    San Francisco, CA
    Not Brembo Calipers on the Euro CSis. Those cars use ATE clampers.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Good to know
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    I could build you a 360mm brembo set up.
    San Francisco, CA
    Thanks for the offer, but I’m content with I have now.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Wadsworth, Ohio
    BMW
    O baby! I love the combo! Can't wait to see it all installed!
    Sunny Cali,
    6.5 second 69 Camaro
    Quote Originally Posted by M6csi View Post
    Nice, Were they a package or can you buy the 2 piece rotors seperate? Tia!
    Iceland
    BMW 850
    Quote Originally Posted by dragon850 View Post
    Would it fit the 18" Hartges without spacers?
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Fatandre View Post
    I think 10" spacers would be needed.
    Sent from my SM-G925T using Tapatalk
    San Francisco, CA
    Wow... With the 10mm spacers, the Hartges/tires (at least in the front) will protrude beyond the fenders. That’s the reason I wanted a more or less plug and play setup. Definitely not a very good look. 3 or 5mm spacers will be needed for the front setup as with the mock-up now, there is about 3-4mm of clearance between caliper and wheel. As with the mock-up now and with the outside brake pad resting on the rotor, there is minimal clearance. Once the calipers are mounted onto their brackets, they will push out the calipers about 3mm or so. Definitely too close for comfort.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    San Francisco, CA
    Quote Originally Posted by 8eights View Post
    They come as a 2 piece Rotor/caliper kit. If one were to buy a pair of new 2 piece hats and rotors from Brembo, they will probably cost about $1200 a side, so about $2400 for the front setup. The complete 2 piece hat/rotor BBK kit will set you back about $3400. Definitely not worth it to but the 2 piece rotors by themselves.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    How wide are the Hartge in the front??
    San Francisco, CA
    Eight and a half inches by eighteen.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    9" front e31 specific alpina classics with 10" spacer. Perfect stance!
    Iceland
    BMW 850
    I am looking for a BBK that does not require spacers for my Hamann PG1 wheels
    San Francisco, CA
    The Brembo BBK’s would be your best bet. There is a e31 specific kit, but it is the same kit that also fit the older 5, 6, and 7 series cars. There are a few other BBK manufactures that make application for the e31 also. Personally, I would stick with the storied Brembo brand and how much more esthetically pleasing they are compared to other BBK’s.
    These are the 2 Brembo kits that would fit our 8’s: 1B1.7009A- GT1 calipers with 332x32mm 2 piece rotors (slotted only). 1B4.7001A- GT1 calipers with 332x32mm with 1 piece drilled rotors. I have this same kit on my 88 M6.
    As for the OZ made Hamann PG1’s and how they fit with the Brembo BBK, I think the caliper/rim clearance will be greater than my setup. The PG1 and the Hartge type C’s (also OZ made) are essentially the same wheels except for the rim centers. The Hamanns have crowned centers that will probably create more space for caliper/wheel fitment, so spacers are not probably not needed. On my Hartges, the centers are slightly concave thereby creating less caliper clearance space. I’ll play it safe just in case and will be adding a 3 or 5mm spacers.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Iceland
    BMW 850
    I have CSI brakes laying on the shelf. Just need new rotors but they are darn expensive and also the calipers are so heavy.
    The discs are 345x32
    I bet that if you would run discs from a 5 series it would not need spacers
  1. OK, final question, how will this wheel and tire combo work?
    By DMVV in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-13-2006, 03:18 PM
  2. WTB: Wheel and tire combo to fit 96 328i.
    By Kompressor in forum Wheels and Tires
    Last Post: 12-28-2005, 07:03 PM
  3. Wheels and Brakes to die for...
    By Nopanegain in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-17-2005, 10:56 AM
  4. FS: BMW OEM 16" wheel and tire combo E39 5 Series
    By pyoon in forum Wheels and Tires
    Last Post: 10-22-2003, 07:12 PM
  5. M3 Wheels and Brake pads for sale on Ebay!
    By kidneykid in forum BMW Parts For Sale
    Last Post: 08-30-2001, 05:06 PM
