Page 4 of 4 FirstFirst 1234
Results 76 to 95 of 95
Thread: LED headlight conversion
  1. #76
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Quote Originally Posted by tvjake2 View Post
    Sale gone now? Back to $69
    Nice
  2. #77
    UAE
    Merc R129, E31, Jag XKR
    Guys, I just want to confirm that these are Euro headlights? Iv got a Gulf spec E31 and im not 100% sure what we got as OE
    If its Euro headlights, I need to order H1 correct?
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
  3. #78
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    They look exactly the same as my Euro lights - so, yes! H1 bulbs x 3 required for each side.
    https://www.meeknet.co.uk/e31/Headlight/Index.htm
    My BMW Repair YouTube Channel
  4. #79
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    The easiest way to tell is US headlight have the black bezel around the whole “headlight” part, Euros don’t. Very obvious difference
  5. #80
    UAE
    Timm, I sent you a PM. Hoping you can help me out with my issue
    Quote Originally Posted by killian665 View Post
    Yep, figured it out after awhile
  6. #81
    Feb 2019
    Bay area
    Bmw
    How do you know if these headlights will work for a 2013 328i?
  7. #82
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by Deschainer View Post
    We don't. You are on the wrong forum.
    Desecrator of all things Sacred
  8. #83
    Boston, MA
    2002tii, Z3, 325ix
    I just installed the Hikari "Eyes of Megatron" LED replacement bulbs for my low beams. Is there any heat generated by the wiring harness or block connector (see photo) that I have to be concerned with contact with the plastic headlamp housing? IMG_5759.jpg
  9. #84
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Some heat is emitted but not enough to damage the housing.
    Sent from my SM-G965U using Tapatalk
  10. #85
    Jun 2017
    Livermore, Ca
    1997 e31
    Thanks for posting this solution...I attempted to order the LED from page one unfortunately they were out of stock. Apparently available now!
    I have a trans failure issue I posted about earlier..discovered it only happens at nite after long/across town trips with lights on- so trying to reduce battery drain as a solution. Not sure of differential in amps between the two (Halogen vs LED)- popped my 2A fluke fuse when testing so unable to measure.
    Anyway I ordered an adjustable beam version https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 for $36.99 the prior posted LED is $69. You may rotate this LED in fixture- not sure why you would want to..directions are given to install with led elements facing left & right. Lumen output is same.
    I purchased the resistors and installed one assuming they were needed- it popped the low beam fuse and apparently draws a bit of current. When testing on a battery the LED element would not light and draws a good spark when connecting leads.
    I reinstalled with no resistor and lights function well with no flickering etc. (One day of testing) A headlight alarm notification was on at restart this am...likely have to live with that issue...
    The resistors arrived from the phillipines after 6 wks...I have a bunch if anyone needs one/two.
    Lane
  11. #86
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Pictures removed because PTC incorrectly soldered:
    Removed 50w resistors from the pop up main beams and replaced with PTC resistors as shown on meeknet. (Link earlier in this thread).I had been advised that I was likely to melt things with the 50w resistors in place. Thanks Timm!
    I hadn’t picked a soldering iron in many years before acquiring this car.
    Not the best looking job, but hidden behind heat shrink.
    All seems good, but still cant resolve why my FTP main beams are non functional.
    I initially suspected polarity, but after switching, still no dice. I reinstalled the halogen bulbs, and no dice there either.
    Is there a relay or fuse specific to these, as everything else headlight related is working?
  12. #87
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The PTC's go in parallel with the LED - not in series - that's why they are not working. All shown here:
    https://www.meeknet.co.uk/E64/Timms_...Fog_Lights.htm
  13. #88
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    I installed the PTC resistors on the H1 LEDs I have in my main beams in the pop ups. Despite being soldered in incorrectly these bulbs function. I’ll fix the according to your link.
    The main beams in my FTPs are the bulbs that are inop. I perhaps should have made a separate post for this issue.
  14. #89
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Forgot to say - the main beams are not checked by the LKM - nor are the FTP main beams, so no need for any resistors of any kind. They ARE needed on the dipped beams and fogs.
  15. #90
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Good to know - my fogs and dipped beams are HIDs. In that case I may leave the pop up main beams as they are, as they are functional.
    The FTP main beams however are still stubbornly not working. I’ve checked fuses 13,14 and 26 and they’re good.
  16. #91
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    K52z could be your man: https://www.meeknet.co.uk/e31/Timms_...lay_Finder.htm
    Also involved is N17, the crash control relay
    Circuit here: http://www.meeknet.co.uk/e31/e31_95.pdf#page=472
  17. #92
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    K52z was reflowed, along with the two pop up relays, by eedegreetodrive.
    I could replace the crash control relay to troubleshoot
  18. #93
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Narrow it down by using an elastic band to keep the stalk in the 'flash' position and check for a voltage on Fuse 26 - voltage present = loom problems, no voltage = something else!
  19. #94
    May 2019
    Grovetown, GA
    1991 850i 6-speed
    Try not to laugh - I had left my fog switch on, and had yet to euro encode my LKM, which is why the FTP main beam wouldn’t come on.
    One I’d used Revtor’s fantastic E31 LKM Coder, the FTP main beams work, and of course the wall of light is a go.
    Last step is to add the bulb holders for the rear fogs.
  20. #95
    Jul 2012
    Redmond, WA
    e39 m5, e31
    I know this isn’t the classifieds but I have some eyes of megatron main beams and resistors if anyone would like to make an offer. They have at most an hour on them I would guess? I went back to all oem
  1. 7" led headlight conversion
    By hakhawk in forum 1975 - 1983 (E21)
    Last Post: 08-30-2020, 05:13 PM
  2. Replies: 8
    Last Post: 06-07-2016, 03:38 PM
  3. LED Headlight conversion...
    By gmtmaster in forum 1999 - 2006 (E46)
    Last Post: 11-20-2012, 11:10 PM
  4. Deamon Eyes/ headlight conversion from Bavarian Autosport..
    By Andre325i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-23-2002, 02:24 PM
  5. Replies: 22
    Last Post: 03-13-2001, 02:59 PM
