Results 1 to 10 of 10
Thread: More 325 Touring S54 swap fun
    Jul 2010
    KC, Mo
    1997 328is
    Well, it's up and running. Amazingly, with no coding work, the stability control is functioning perfectly !! The few dash light issues have been resolved. However, the one nagging issues is E46 M3 code 106. The reason I specify the model is that the codes are different for the M vs non-M cars (I assume because the very different DMEs). The specific code is "106 Signal, brake light switch".
    I have used newTIS.info to run down the wiring info. So, the fuse is good, the brake lights work, and I have swapped the switch with my 2002 E39 as they are identical. The problem is not the switch. The cruise control light does come on, but the cruise is not working. I have to assume the the lack of signal is telling the cruise control to think the pedal has been depressed.
    So, the questions -- anyone know if this is a coding issue, and is anyone familiar with this?
    dworthy's Avatar
    Nov 2010
    Hohenfels, Germany
    16 220i 05 325it 05 M3
    Have you checked to see if the signal is reaching Pin #24 on the DME?
    Darin
    Current:
    05 M3 Imolarot II(405)/Gray(N5TT) ZCW, ZPP 6sp Manual C.F. Lip, CSL diffuser, Euro Infra-Rot front windshield and a trunk liner! Mr. Go_Fast Stored for the Winter
    Past:
    95 318is Montreal Blue Met (297)/Beige(K1SN) A Hooptie!
    84 M535i gray market Burgandy Rot Met/Black Leather Lowered by Intrax on bilies, poly everywhere, B&B cat back system, K&N, and a hitch! Da Beast - Still running w/375k+!
    91 316i euro Tizianrot/Gray cloth - E-36 w/M-40 motor, such a beater, but great on gas! Best was 38 MPG
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2010
    KC, Mo
    1997 328is
    Pin 24 of which of the five plugs, and what should the signal be? Voltage, ground?
    dworthy's Avatar
    Nov 2010
    Hohenfels, Germany
    It will be a Blue with Red stripe and yes power. Also have a look at #28 for that should be a ground Brown with green. Check plug number X60004 40 pin black connector.
    Are you getting and codes in the LCM? Can you turn on the brake lights thru your test equipment?
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2010
    KC, Mo
    1997 328is
    I am sort of confused. The diagram does show pin 28 leaving the brake light switch and going to the DME, and is brown/green. The blue/red is power, but that said, the car's lights are all operating properly, including brake lights. (I will not be able to check the car until tomorrow.)
    No codes from the LCM that I can see with me Snap-On Solus. I have a new version of INPA coming and that should get me deeper into the car. BTW, I swapped the brake light switch with m E39, and the E46 still throws the code and the E39 does not, so the switch can be eliminated as the source of the problem.
    dworthy's Avatar
    Nov 2010
    Hohenfels, Germany
    Got it, switch is good.
    Now as you do know it is sending that signal to two places: DME and LCM. What I am worried about is that even though the wiring diagrams say that is where those two wires should be on both models, I just wanted to make sure you are getting the ground, power and they are in the correct plug.
    Also when INPA comes in, it will tell you if the fault is current or sporadic, and check the pending codes too, for Solus doesn't do that as far as I know.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2010
    KC, Mo
    1997 328is
    Good points. It is my understanding the LCM has the VIN coded into it. If so, it may not recognize info coming from a component with a different VIN (the S54 DME).
    dworthy's Avatar
    Nov 2010
    Hohenfels, Germany
    Correct, and while it is thinking that you still have a M54-B25 under the hood, you may have to change the VIN in the DME, EWS, and LCM. I would check with a local tech or over on the General BMW Mechanical Help subforum, as there are several dealership level techs on there.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2010
    KC, Mo
    1997 328is
    "while it is thinking that you still have a M54-B25 under the hood"..... What is "it" referring to.
    EWS has been disabled but the EWS is showing a code for a dissimilar VIN. Given what the EWS does, I doubt that it is root of the 106 brake switch code and 139 cruise interrupt codes.
    I will check on realigning the DME and LCM VINs.
    What I do NOT want to do is kill the DME by fiddling with the VIN in there. I would think that realigning the instrument cluster and LCM would be safer.
    But, I am proud to admit that I am smart enough to know when I am NOT !!!!
    dworthy's Avatar
    Nov 2010
    Hohenfels, Germany
    I would PM this guy: 328 Power 04 He is a guru with the DME's and other ECU's on that car.
    Darin
    Current:
    Past:
    M-Flight Member
  1. MORE E46 S54 swap fun
    By snaponbob in forum Engine Conversions
    Last Post: 01-19-2018, 11:55 AM
  2. E46 Touring - S54 Swap - Build Thread!
    By 95///M3 in forum Engine Conversions
    Last Post: 01-15-2016, 05:08 PM
  3. S54 Swap Harness and ECU Flashes -- e36, e46, and more!
    By M3Rob95 in forum Engines, Performance Parts & Software
    Last Post: 04-06-2013, 08:02 PM
  4. More S54 swap mayhem: Sia's E28.
    By Mystikal in forum BMW Rides & Events
    Last Post: 12-21-2012, 01:39 AM
  5. E30 FS: 1991 318i TOURING - M50 Swapped and more
    By NHskibm in forum E30 Parts Classifieds
    Last Post: 01-27-2009, 02:42 PM
