Bavarian Soundwerks
Results 1 to 5 of 5
Thread: Radio signal (microwave) from inside dash region every 7-10 seconds on e39 530i
    New Zealand
    1998 318ti, 2003 530i
    Any ideas what could be causing a regular radio signal to be sent from somewhere beneath/inside the car dash? - behind central air vents? It happens about every 10 seconds and lasts about 4 seconds. I know because I have a microwave RF detector. I want to kill this but not sure how or what is doing the transmitting... The car has a hands free phone kit (aftermarket?) so wonder if this is doing it. I don't need nav or phone setup so if there were an easy way to pull a fuse on all these functions that would be great and might solve this. Here is the car from bmwvin.com:
    VIN WBADS62040GL81691
    Type Code DS62
    E Series E39 (2)
    Series 5
    Type TOUR
    Model 530I (EUR)
    Steering RL
    Doors 5
    Engine M54
    Displacement 3.00
    Power 170
    Drive HECK
    Transmission AUT
    Colour BLACK SAPPHIRE METALLIC (475)
    Upholstery STANDARDLEDER/SCHWARZ (N6SW)
    Prod. Date 2002-10-10
    Available upgardes
    Spare/replacement key fob Check compatibility
    Vehicle options
    L807A NATIONAL VERSION JAPAN
    S202A Steptronic
    S204A Drive layout, export
    S220A Self-levelling suspension
    S249A Multifunction f steering wheel
    S261A Side airbags for rear passengers
    S354A Green windscreen, green shade band
    S361A BMW LA wheel, parallel spoke 82
    S386A Roof railing
    S403A Glass roof, electrical
    S423A Floor mats, velours
    S428A Warning triangle and first aid kit
    S430A Interior/outside mirror with auto dip
    S431A Interior mirror with automatic-dip
    S441A Smoker package
    S459A Seat adjuster, electric, with memory
    S470A Isofix-System
    S473A Armrest front
    S494A Seat heating driver/passenger
    S500A Headlight wipe/wash/Intensive cleaning
    S520A Fog lights
    S521A Rain sensor
    S522A Xenon Light
    S534A Automatic air conditioning
    S548A Kilometer-calibrated speedometer
    S555A On-board computer V with remote control
    S601A TV function
    S609A Navigation system Professional
    S646A Preparation f teleph.installation Japan
    S676A HiFi speaker system
    S694A Provisions for BMW 6 CD changer
    S773A Fine wood trim
    S818A Battery master switch
    S823A Hot-climate version
    S845A Acoustic belt warning
    S853A Language version English
    S876A Radio frequency 315 MHz
    S925A Dummy-SALAPA
    S992A Control of number-plate attachment
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Probably BT module for hands free.
    New Zealand
    Quote Originally Posted by Mless5 View Post
    Thanks. I took out fuse 58 in the back of the car above the battery (touring model) and this stopped the microwave transmission. It also of course turned off the radio and onboard computer so this isn't the fix I'm looking for.
    Presumably hands-free is an aftermarket mod as it's not listed as an option for the car? Rather than pulling the dash to pieces to try and find this tiny module wherever the previous owner installed it is anyone aware of a fuse to pull or a wire to cut power to the whole phone system while keeping the radio and onboard computer and sat nav alive?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think you’re going to have to start pulling the head unit as it seems the BT module is on the same fuse as the head unit. PM denniscooper. He’s an E39 guru.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi
    Marco - I'm not so knowledgeable when it comes to installation of various modules for the potential many electronic gadgets which could be in a car! This also I suspect isn't an E39 specific issue as well!
    E36elf - You'll need to begin fault finding by pulling fuses to see if the microwave emission stops and then begin to trace wires to whatever the source could be. Just a stab in the dark and someone perhaps installed a car alarm microwave sensor incorrectly ? Else it might be a faulty unit of 'something' that is failing and causing the output or perhaps maybe even a tracking system of some sort.
    Cheers, Dennis!
  1. Brake pressure regulator "cycling" every 5-10 seconds
    By mojocoggo in forum 8 Series (E31)
    Last Post: 08-14-2021, 05:21 AM
  2. X5 just came back from the dealer with no radio signal
    By Canyonlands in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 08-13-2010, 05:19 PM
  3. From 245/40 R18 to 225/50 R17 on a 530i SP??
    By babak in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-10-2009, 08:19 PM
  4. weak radio signal with new in dash dvd player
    By 1995red318i in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-13-2002, 02:57 AM
