Results 1 to 9 of 9
Thread: FS: 1992 325i / E34 525i TURNER MOTORSPORT PERFORMANCE CHIP
    Pittsburgh, PA
    94 325ic, 08 X3 3.0si
    This performance chip is for the 1992 E36 325i and the E34 525i with the m50 2.5l engine. $50 OBO
    Chip# T403-000
    Fits only BOSCH ECU# 0 261 200 403
    The chip is copyrighted 1997 but the programming is still exactly the same as the newer chips. I called Turner myself to make sure.
    TURNERS PART DESCRIPTION
    A Turner Performance Chip for the 1992 E36 325i is an absolute MUST-HAVE performance upgrade. This chip was developed on the dyno to increase horsepower and torque from low RPM all the way up to the new 7000 RPM rev limit. Engine management expert Jim Conforti tuned the fuel and spark mapping to maximize output when used with 91+ octane fuel. More power, a smoother engine, and better response are the results. Bang for the buck, this is hands-down the best upgrade to do. The rev limiter is raised to 7000 RPM and the top speed limiter has been deleted.
    Turner Performance Chips provide the ultimate in performance advantage! Adding a performance chip to your BMW is the easiest and most cost effective way of increasing BMW power, torque, and performance with NO DOWNSIDES. Through years of BMW performance tuning, we are able to maximize power and torque gains for 91 octane fuel used in North America. By making changes in the ignition and fuel maps of the DME we are able to optimize performance with no side effects or compromises. Other changes will make your BMW smoother and more responsive than when it left the factory. Our chips have a lifetime warranty and a 30-day satisfaction guarantee. If for any reason you are not fully satisfied with the increase in power and overall drivability you can return the chip to Turner Motorsport for a full refund. Chips are supplied with detailed instructions and are user-installed in about an hour. See below for specific information that we may need from your BMW model.
    Horsepower Gain: +20 @ 6,000 RPM
    Torque Gain: +13 @ 4,500 RPM
    New Rev Limit 7,000
    Required Vehicle Info
    E36 325i/is 92 Bosch ECU part number, beginning with "0 261"
    This performance chip fits the following BMWs:
    1992 E36 BMW 325i 325is
    ASKING $50 OBO
    Pittsburgh, PA
    bump. added pics
    Pittsburgh, PA
    Bumpity bump.
    Pittsburgh, PA
    Price Drop.
    Feb 2016
    Rogers AR
    1995 BMW M3
    Does this not fit the red label 413 ecu?
    Just double checking and seeing if it was a typo by chance
    Pittsburgh, PA
    I'm not too sure. I would contact TurnerMS and ask them if it would.
    If you have a 92 325i with the m50 2.5L engine it'll most likely fit, but I'm not 100% in your case.
    Do you have the ECU beginning "0 261"?
    The ECU I pulled it out of ended in 403, so I figured it only fit that one. I could be totally wrong.
    Pittsburgh, PA
    bump
    Pittsburgh, PA
    still available
    Pittsburgh, PA
    bump
  1. FS 93-95 e34 525i Turner Motorsport Conforti Chip
    By Rick525i in forum E34 Classifieds (closing soon)
    Last Post: 06-30-2016, 02:23 PM
  2. E36 E36 or E34 Turner Motorsports Performance Chip after 12/94 325i/525i
    By blitz355 in forum Engines, Performance Parts & Software
    Last Post: 04-05-2012, 08:37 PM
  3. BMW E36 325i, E34 525i Turner Motorsport Performance Chip 413-000 TMS
    By Blackedout325i in forum Engines, Performance Parts & Software
    Last Post: 11-13-2009, 04:54 AM
  4. E36 325 1993-1995, E34 525i, Turner Motorsport Conforti Performance Chip 22hp gain
    By BRUNO in forum Engines, Performance Parts & Software
    Last Post: 07-18-2007, 11:02 AM
  5. 92 325/525i Turner Motorsport Performance Chip
    By 95TsiAWD in forum BMW Parts For Sale
    Last Post: 06-20-2006, 07:04 PM
