Results 1 to 13 of 13
Thread: 2004 X3 purchase. Need advice
    boston,new york
    1996 m3 coupe
    Hello. I'm looking at a 2004 X3. 156k on the clock. It has some engine codes so I wanted to see opinions on whether the issue is serious or possibly get some thoughts on what the issue could be. Thanks in advance.
    Sent from my XT1635-01 using Tapatalk
    What's your budget? What's your mechanical experience? If you need the injectiors, full service of fluids, filters, sensors, plus what comes up as you clear each code.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Using Tapatalk
    boston,new york
    1996 m3 coupe
    I'm pretty experienced with bmw. I ended up buying the X3. So now I have to sort through it, which will be fun.
    Pictures, how does it run, options, and price info would be good.
    Using Tapatalk
    Quote Originally Posted by bigmitch117 View Post
    Between the misfires, bad sensors and steering angle issues, I believe the issue is deferred maintenance and it's going to be a pain. All you can do is fix what is dx as broken, but it might not be financially wise.
    Using Tapatalk
    boston,new york
    1996 m3 coupe
    Well, I have a laptop to diagnose the issues and time on my hands. From what I gather parts aren't that expensive either. You're opinion is probably right if I were to rely on a shop to fix it
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Looks like vacuum leaks from old rubber, possible bad coils or worse (head gasket). Does it run hot
    boston,new york
    1996 m3 coupe
    No, it runs at a normal temp. It's 12 degrees F. Here though, so we'll see if it runs hot in summer. I will definitely be checking vacuum leaks, but I doubt all the coil packs are bad since I'm getting misfires in all cylinders
    Depends on the part, obviously. If one of the cpus goes bad, happened to my 01 330, it's pricy. Tyranny problem, how good are you? Either keep us posted with your progress. I had an 06 before my 13 and liked it. You don't say what motor, but I had the i6
    Using Tapatalk
    boston,new york
    1996 m3 coupe
    It's the 3.0 i6. Really enjoy the way it drives so far. Did my first oil change on it last night.
    Oct 2007
    Middle TN
    Too many/Not enough
    I had the 281c and 281d BSD codes. Ended up being caused by an aftermarket alternator not integrating properly into the BMW software. The alternator would charge properly and I had no other issues related to these codes. I purchased a lightly used BMW alternator and it cured the problem. It sounds strange, but these codes can also be triggered by the oil level sensor installed on the bottom of the oil pan. Good luck.
    Current Garage:
    91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
    91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
    06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
    03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
    05 X3 3.0i -family workhorse - diamond schwarz
    12 X5 3.5d - torque monster - space gray metallic
    86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
    08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
    88 Schwinn Sierra - 1WD Off Road Vehicle
    e31 & OHC BMW CCA #385540
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    There could be many reasons of course, but I got those mixture prep codes along with occasional misfire codes when the DISA valve suddenly crapped out in my car. If you have any grinding noise that comes from the intake/driver side of the engine, that's most likely the reason. It is fairly easy to check and replace.
    boston,new york
    1996 m3 coupe
    Upstate. 3/1/18. I replaced the intake boot and all the lean codes I was getting, went away. The check engine light came back on though for "vehicle speed sensor"
    Is there another speed sensor besides the wheel speed/abs sensors?
  1. 1988 635 CSI Purchase. Need Advice
    By Jay9 in forum 1976 - 1989 (E24)
    Last Post: 07-01-2011, 09:08 PM
  2. Considering a purchase...need advice
    By TarheelMBS in forum 2004-2010 (E60,E61)
    Last Post: 01-22-2011, 12:21 PM
  3. Possible purchase. Need advice.
    By fast1eddy in forum 1976 - 1989 (E24)
    Last Post: 05-12-2009, 05:23 PM
  4. On the verge of a purchase, NEED ADVICE
    By dkl2001 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-19-2008, 10:51 PM
  5. 2004 325i - 23k Need Advice
    By bimmer4bob in forum BMW Cars For Sale / Wanted
    Last Post: 11-19-2006, 08:54 PM
