Page 4 of 8 FirstFirst 12345678 LastLast
Results 76 to 100 of 181
Thread: Vibration persist after replacing engine and transmission mounts
  1. #76
    Feb 2015
    Phoenix, AZ
    1997 740iL (5/96 build)
    Quote Originally Posted by georgebest View Post
    Say if I managed to remove the "Jesus bolt", do I need a puller to remove the flange or it just comes off? Like a wheel hub puller or similar. Thanks!
    It will just pull off.
  2. #77
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by cyclops2 View Post
    Thanks! Just waiting for the BMW tool, hope to get it tomorrow. Should go working out today!
  3. #78
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Madnass!
    Got the tool and a 40 inch 3/4 breaker & socket... still doesnt move. Time to make that breaker longer
  4. #79
    Feb 2015
    Phoenix, AZ
    Longer break??!!!....lol. .....oh, breaker. Right. Plus did you have your Wheaties?
  5. #80
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    This seriously makes feel weak )
  6. #81
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    You need to seriously put your weight into it. It's tight AF.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  7. #82
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by clarkitect View Post
    So far...George vs Jesus Bolt: 0-2
    If car wasnt in the garage i'd just tie a rope around the breaker and have it pulled with another car Cant do it in the current set up unfortunately.
    I'm spending more time on this one bolt than the whole TCG update, I would be ready by now
    Next up a long pipe, if not working I need to try some pneumatic or electric impact wrench. There are some with 1200 ft.lbs of max breakaway torque, that should be plenty for something originally troqued for approx 400Nm.
    Anyway, pipe should work!
    ...and yes, I should probably work out more
  8. #83
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    V I C T O R Y!!!!
    It's out! For future incompetents like me, here are the tools used:
    Performance Tool W34122 3/4-Inch Drive 40-Inch Jumbo Breaker Bar
    Sunex 427md 3/4-Inch Drive 27-Mm Deep Impact Socket
    BMW Crank Holder 83300490894
    The trick was to instead of pushing it using my leg and arm muscles, pulling it from the otherside using my body mass. You can make the conlusion about my muscle vs fat ratio on your own )
    Finally! Now back to the original job... after a 3 days detour. I should frame this bolt or something.
  9. #84
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    And some pictures!
    This is how the genuine BMW tool looks like, fan clutch tool for comparison:
    It certainly doesnt have that cool MadMax feel as the tools you guys put together
    Behind the cover of course it's full of broken guide pieces everywhere. I'm surprised that this engine even worked. Chain is extremly loose, no wonder it had timing issues.
    More interestingly the upper oil pan gasket broke, no surprise there it was 18 years old, see picture below. It would be too much work to remove it. Do you guys think that gasket maker would do it here?
  10. #85
    Rutland, Vermont
    Get a new gasket and just use the front piece with some RTV in the corners. You’re right, changing the upper oil pan would make the Jesus bolt look like cake. If the old piece is whole you might be able to use it again with some RTV on it.
    You’re on the home stretch now!
  11. #86
    Feb 2015
    Phoenix, AZ
    coming along now. good job.
    1997 740iL; 5/96 build. Purchased 12/04. Off the road build project 2013 - 2021. back on road 3/2021. Became daily driver (only vehicle) 6/12/2021. Still not completed. Stay tuned as the adventure continues.
  12. #87
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    Mine broke in two places, most sticking to the lower cover. Carefully removed it, cleaned all surfaces and skinned RTV top and bottom.
    Let the gasket cure for an hour on the oil pan edge, then skinned a thin coat on the cover, with an extra dab where it cracked, and in the corners. Torque to
    specs and continue. No leaks at all after 15k. Much easier than pulling the engine to replace the upper pan gasket!
  13. #88
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    I did like Clark described and worked perfectly for me. No leaks in over 2 years.
    '01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
    '99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
    '84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
  14. #89
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    For those that read this in the future, I was extra careful pulling the lower cover and got mine to stay intact. Key is to lift the cover as much as you can (it's not much because there are two centering dowels at the bottom and use a putty knife or something very thin to separate the gasket from the lower cover.
    Then gently lift the gasket to skim along the oil pan and then do the top for the cover.
    What was mentioned here for broken gaskets is more than sufficient and will work fine.
  15. #90
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by racer2086 View Post
    There was no way to pull off mine gently, for a while I was wondering if I missed a bolt it was so strongly stuck together. I had to use a hammer as a crowbar to pull the whole thing apart.
    Thanks for the tip, will get a new one and use only the front part + RTV.
  16. #91
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    We should have a badge system with different levels:
    Level 1: fixed glovebox
    Level 5: Jesus Bolt
    Level 8: Upper oil pan gaskets without lift
    ..and so on Not sure what highest level would be.
  17. #92
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Got a bunch of parts, but not everything though at least I could move forward a bit.
    Any of you had a hard time with the teflon seal replacement on VANOS? On one unit I had no issues at all, on the other one I already tore apart 5(!) seals. No matter how well it fits when I push in the cylinder it gets dislodged and torn. Raj from Beisan trying to figure out why, I might need to buy a rebuilt unit if not succeeding. Let me publicly shame this part!
    Bracing in for putting the jesus bolt back this weekend, bottom cover cleaned nicely:
    New guides, chains and even some bolts, starting to come together:
    and down with the old! Probably wouldnt sell well on Ebay:
    Fun project so far, not counting the Jesus bolt and the teflon seal
  18. #93
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    also kind of interesting, look how hard the chain was hitting the cover. This car was probably miles away from a broken chain, I got really lucky!
  19. #94
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    I'm really surprised how small the torques are that BMW sets for the timing chain bottom cover. I only have M6 & M7 bolts so 10-15Nm, would have thought minimum 15-22Nm but will do whatever they say, used Loctite 242 on all bolts at least.
    What a beauty tho:
  20. #95
    Jan 2017
    Agreed George, these are elegant engines. Simple to work on mechanically. It really is a shame how
    many hit the skids for a few hundred dollars of guides and gaskets.
    You will be proud of yours!
  21. #96
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by oldroller View Post
    Cant wait to start it up! Have to sort out the VANOS teflon seal issue first though, so probably not for another week or two.
    Something else: is there any sensor monitoring the transmission oil level? I have noticed some leak around the tranny oil cooling line, where it enters the heat exchanger. How would I know if oil level is low in transmission? Other than going over the whole procedure to warm it up, put the car on jacks etc. Thanks!
  22. #97
    Jan 2017
    Unless you have the dipstick mod it's the long version. Jack stands, level, cold, should just dribble when the side bolt is removed.
  23. #98
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    If I removed the side bolt when cold oil would rush out, has to reach a certain temperature in the transmission and then open it. Done it a few times just thought maybe there was a sensor in it to warn for lower level. Anyway, first I need to solve the VANOS issue, nothing will warm up till then!
  24. #99
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    This for the benefit of anybody planning to do the Beisan VANOS update:
    if the Teflon ring properly placed in with all waves smoothed out but still gets pulled down with the shaft, your VANOS inner plastic is most likely cracked. Unfortunately, there is no easy way to check it. My two units looked identical, one upgraded with no issues but it was impossible to do it for the other one.
    Ordering a rebuilt unit from Dr. Vanos for net $250 after core charge return.
  25. #100
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Now finally having both VANOS unit and putting on the timing chain. But the new chain (IWIS) is extremely tight! To the level that the only way to putting on would be turning the engine with the chain half way on so it will slowly get in place (see picture below):
    So the question is: can I remove the pin locking the engine into position and turn it until the chain gets in place or that could destroy something? Otherwise I have no idea how to put this on!
    The concern is obviously to damage a valve or something, I have the timing tools screwed on to the camshaft, but not sure in what position that looks the valves.
  1. How to predict the acceleration of the car after the engine and transmission upgrades
    By foler in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-08-2012, 03:42 PM
  2. Replies: 3
    Last Post: 08-25-2011, 01:41 AM
  3. FS: Vorshlag Engine and Transmission Mounts for E36 LSX
    By RahgBag in forum Engine Conversions
    Last Post: 11-09-2010, 05:31 PM
  4. 540i6 engine and transmission mount options?
    By toyotahachiroku in forum 1988 - 1996 (E34)
    Last Post: 08-06-2010, 06:52 AM
  5. FS: UUC Racing Engine and Transmission Mounts
    By jwilly in forum Race Cars & Track Parts
    Last Post: 09-11-2008, 02:49 PM
