Hello all,
The drivers seat in my E31 has developed the infamous "twist". From searching previous posts on the forum some users recommended a repair kit supplied by Seatguru429 AKA Paul, to whom I have sent an email but as of yet haven't received a reply.
To keep options open, is anybody aware of a repair kit or solution available in the UK?
Cheers.
There are repair instructions around that need no new parts - the plan is to reduce the length of the OUTER of the Bowden cable so that the inner mates properly again. Shogun will know all about this as it was first tried on the E32 - but a quick search of 'BMW seat-back twist' should help you out!
https://www.google.co.uk/search?q=BM...hrome&ie=UTF-8
My BMW Repair YouTube Channel
Blowtorch, some pliers and maybe a knife is all you need.
Shogun's DIY is appropriate for our seats, but if you want to be visual instructions, search YouTube for "e39 seat twist fix".
see my website below, detailed instructions with pics, fixes>>>seats>>>Untwisting the seat back
The seat in my '91 was 'jacked up' when I bought the car. I removed seat and found the seat rails and back of seat were both uneven. One of the cables that operate the 'lift' of rear seat was stretched so cable drive was not engaged with motor. The outer cable housing only needs to be shortened about 6mm. I plan to shorten both sides.
I removed the bottom rail section of seat and pulled cables out of motor drive mechanism. Cables appeared to be engaged in motor drive. So I used a electric drill and inserted cable drive into drill chuck. Running drill very slowly revealed one cable that was not operating screw mechanism in rail. I disassembled one side of rail and found the nylon gear on long screw shaft was cracked. I had a jeweler make a rubber mold and reproduce the gear in brass. Reproduction shrank about .45mm and the very fine splines did not come out accurately so I have a machinist who is going to cross drill the gear and shaft and use a roll pin to mount the gear.
I should be picking up assembly in the next day or two. Some of the guys on here found a automotive instrument/odometer shop that rebuilds gauges and he can make a plastic reproduction but you must send him your gear and he can only make one per gear. That is why I went the route of mold making/ casting process.
The odometer shop in the NE USA is: http://www.odometergears.com/product...s+E31+89-99/40
Did mine last week. Took me about 30 minutes. No need to even unbolt the seat.
Just google BMW twisting seat and there are videos showing how on the E39 however the process is the same
1998 e31 840ci Sport, Individual. 2008 Aston Martin DB9. 2016 4.4 SDV8 Range Rover Vogue.
1959 Triumph Bonneville, 1969 T120R Triumph Bonneville, 1975 T160 Triumph Trident, 1990 Harley Davidson Fat Bot Grey Ghost, 2009 Triumph Bonneville 50th Anniversary model. 2014 Suzuki Gladius.
A local machinist I use finished mounting the cast brass gear I had made for bottom seat rail mechanism. The castings weren't perfect and ID needed to be reamed to correct size so gear could be pressed onto spline shaft. We thought it might be necessary to pin or use a set screw but after squaring up and reaming the gear he was able to press it onto spline shaft for a very tight fit.
So I can put driver's seat back together and possibly drive my car this weekend for the first time! I completed a partial brake job this past week, just hoping the master cylinder and booster work properly.
