Results 1 to 3 of 3
Thread: Driveshaft compatibility. Diff flanges
    Apr 2014
    Castlegar,BC,Canada
    94e36M3RIP, 95 318 S50
    Im an e36 guy. I have a couple questions about driveshafts.
    First. Are coupe and sedan the same length?
    Second. Is there more than one 188 medium case input flange? Are they all cv flanges of same diameter?
    I am assuming If i get a driveshaft from a zf5 with a 188 diff it should work regardless of any other variables.
    Apr 2014
    Castlegar,BC,Canada
    Looks like the early m52 328 e46 sedans had a rear ujoint 4bolt diff flange.
    I am trying to figure out what driveshafts i can use to manual swap a late model 330 coupe with a zf5 speed.
    I guess unless i just use the front 1/2 of the 328 shaft or switch the diff flange, i wont be able to use the 328.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    RealOEM.com is your best place to find out the information on this issue. Keep punching in different models and look at the flange and drive shaft information. It will also list what other models use the same parts.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
  1. WTB: bolts, driveshaft to diff flange 98' M3
    By Demon Speed in forum BMW Parts Wanted
    Last Post: 04-28-2009, 05:50 PM
  2. Separating Driveshaft from Diff Flange?
    By ggantt in forum 1992 - 1999 M3 (E36)
    Last Post: 01-22-2006, 04:02 PM
  3. WTB M3 6 Bolt Diff Flange
    By Mark Francis in forum BMW Parts Wanted
    Last Post: 02-03-2003, 10:28 AM
  4. WTB 6 Bolt Diff FLange for M3
    Last Post: 02-01-2003, 07:52 AM
  5. WANTED: 95 M3 driveshaft and diff
    By Bond, James Bond in forum BMW Parts Wanted
    Last Post: 11-08-2002, 01:01 AM
