RM European Auto Parts
Page 3 of 3 FirstFirst 123
Results 51 to 73 of 73
Thread: 2000 BMW 323i
  1. #51
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    abel - i think they already tried that - or, at least, did something like that.....
  2. #52
    Jul 2004
    Houston, TX
    36 Cylinders
    Oh, well, then a qualified mechanic would be best then. If the dealer is recommending MAF and oxygen sensors, then they aren't the place to go.
    In order to get mixture deviation codes, that pretty much means the oxygen sensors are doing their job.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  3. #53
    Jan 2018
    Washington D.C.
    2000 323i
    Morning everyone. Took the car to a family friend who is a family friend and he started to take the engine apart bc like you, he suspected a leak. He found it. The ccv has a crack in it and there is oil everywhere. He had me order the following parts...
    Sent from my LGLS755 using Tapatalk
  4. #54
    Jan 2018
    Washington D.C.
    2000 323i
    Meant to say also a certified mechanic*
  5. #55
    Jul 2004
    Houston, TX
    36 Cylinders
    Don't buy URO brand unless you want to do the job again in 6 months.
    -Abel
  6. #56
    Jul 2004
    Houston, TX
    36 Cylinders
    Also stay away from Meyle, Dorman.
    OK to use are Original BMW, Febi/Bilstein, (even Vaico/Rein may be decent).
    -Abel
  7. #57
    Dec 2013
    Chicagoland area
    EXOTICS
    Cancel the order from ROCKAUTO,
    as that part is included in the kit from FCP!
  8. #58
    Jan 2018
    Washington D.C.
    2000 323i
    Thx on the cancellation. All parts will be in this week. I'll keep everyone posted on the results
  9. #59
    Jan 2018
    Washington D.C.
    2000 323i
    As expected by everyone, mass vacuum leaks, rotted hoses etc...getting repaired now
  10. #60
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Thank-you for coming back and closing the loop on this, as it will help other in the future if they come across this thread during a search.
    Yes BMW's are very fickle to vacuum leaks, while you can have a small one here or there, they do add up and cause problems.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  11. #61
    Jan 2018
    Washington D.C.
    2000 323i
    I def appreciate everyone's assistance and patience with me and all my questions. You guys were very helpful and was giving the correct answer from the beginning. Ive learned a lot from this situation. I will keep everyone posted on the final outcome. Thank you all very much.
  12. #62
    Jan 2018
    Washington D.C.
    2000 323i
    Thank you all for your assistance. Im finally back on the road and the car is riding smooth. I def learned a lot from you all and will continue to follow everyone to learn more. Thanks again!!
  13. #63
    Dec 2013
    Chicagoland area
    EXOTICS
    Looking good, glad problem was solved!
  14. #64
    Jan 2018
    Washington D.C.
    2000 323i
    Thank you lol
  15. #65
    Jul 2004
    Houston, TX
    36 Cylinders
    Got pics of the parts which were causing issues? Your car's problems are a recurring theme here, and it would help overall.
    -Abel
  16. #66
    Jan 2018
    Washington D.C.
    2000 323i
    Unfortunately not, however these are the parts i had to replace. I used every item in the pics
  17. #67
    Mar 2003
    St. Joseph, Mo.
    great - now that this issue is fixed - just thought this was worth mentioning again.....
    actually, you are in luck - the National Capital chapter of BMW Car Club of America has an amazing and awesome DIY program. Join the club (www.bmwcca.org) and check out your local chapter. They can certainly recommend a great shop as well.
    one of the best ways to learn is get involved with your local BMW CCA chapter's DIY program - show up, ask questions, learn, pick up a service manual and read it cover to cover. i really like the see one, do one, teach one methodology for learning about working on cars.
  18. #68
    Jan 2018
    Washington D.C.
    2000 323i
    Ok. Thanks
  19. #69
    Jan 2018
    Washington D.C.
    2000 323i
    Hey everyone, back again with a new question. Both my front turn signals just went out. I’ve changed the bulbs and that isn’t the issue. Any suggestions are greatly appreciated.
  20. #70
    dworthy's Avatar
    Nov 2010
    Are you getting the fast blink? Do they work if you hit the hazard switch? Do the lights come on properly when you switch to "Parking"?
    Darin
    Current:
    Past:
    M-Flight Member
  21. #71
    Jan 2018
    Washington D.C.
    2000 323i
    They don’t work at all unless I take the lens out and slightly touch the bulb. When I do that, they work perfectly for a while before going out again. I’m thinking a possible short but it’s strange that it’s both at the same time
  22. #72
    dworthy's Avatar
    Nov 2010
    Ok, what I would do is clean the base of the lamp and the socket, then bend the base contact upward to apply more pressure to the base of the bulb.
    Darin
    Current:
    Past:
    M-Flight Member
  23. #73
    Jan 2018
    Washington D.C.
    2000 323i
    Ok thx
  1. 2000 BMW 323I BLACK WITH CAMEL LEATHER INTERIOR "SHARP"
    By twinned358rx7 in forum BMW Cars For Sale / Wanted
    Last Post: 03-09-2005, 12:12 AM
  2. 2000 BMW 323I with 44,5xx Original Miles For Sale
    Last Post: 03-05-2005, 11:26 PM
  3. 2000 BMW 323i in PA, $17K
    By slilley in forum BMW Cars For Sale / Wanted
    Last Post: 09-13-2003, 07:41 PM
  4. 2000 BMW 323I, 34k - $23,500
    By pdaly in forum BMW Cars For Sale / Wanted
    Last Post: 03-25-2003, 10:08 AM
  5. FS: 2000 BMW 323i - Supercharged
    By Chupacabra in forum BMW Cars For Sale / Wanted
    Last Post: 02-18-2003, 05:42 PM
